My Turbo/Motec Build
#236
#237
Can only imagine, man. The culmination of all the money, hard work, sweat and tears is really what makes doing what we do worth it, and my build is small fries compared to what you've got goin on down there.
Stoked to see how the rest of the season pans out for you and the car.
That sequential is straight sex, I don't even want to lookup the cost, but if I find 20K buried in my back yard, maybe I will
#239
Couple reasons. First is I grew up racing cars with synchro boxes, shifting them hard and fast was always crucial for shift speed and keeping in boost. Sometimes if you just shifted it soft it simply would grind and kick you out. Shift it hard, and it would grind... but at least go in. Once I got this car turbo'd it was still on a synchro box. We had a shift cut set up in the Motec, but keeping the car in boost and not being too hard on the engine meant shifting it fast so it wasn't on the cut for longer than it needed to be. Now with this trans we are using a strain gauge. It requires "x" amount of force to trigger the cut. If you set it up to cut with very little force there is a chance the trans still won't engage. If you set it up to where it requires a decent amount of force the trans basically can't not shift. So that is how we have it.
#240
