My Turbo/Motec Build
#241
By synchro did you mean dog gear, in which case you meant non-synchro? Your sequential dog-gear gearbox connected to a Motec ECU is one of the most sophisticated setups on any S2k on the forum. Do you have the full clutchless auto-blip downshifts and clutchless WOT upshifts configured? I imagine your not using it, but doesn't it also have a builtin oil pump for cooling?
Yes I am using full clutchless up and down shifts. The downs could use some dialing in, but for what I am doing with the car we haven't spent too much time on it. The trans has the provisions for an external cooler, but I am not using one.
#244
#245
#246
thanks for the explanation.
Only reason i asked is because i see people with normal cars on track days treating their gearbox like a piece of shit and wonder why it breaks.
Its one amazing car and the smile on your face every time you start it up must be massive!
#247
Nice interview you had with HP Academy Stu.
BTW, what intake are you running? Noticed the dual rails and that's what I need.
#248
Very impressive.
Could you elaborate on the fuel system and the block? There is a post about it being sleeved...but no details or info on head studs or gaskets.
If the Magnus clutch control is ECU controlled, and you adjust it with a dial through the ECU?
Spoolin (04-24-2019)
#250
The valve is logged, but can only be adjusted manually with the knob. Obviously triggered by the ECU as well.
Fuel system is -6 feed and return, Fore FPR, ID1000 primaries, ID1700x secondaries, brushless pump (probably won't be able to get one yourself), a pretty basic RC car controller, and then a voltage booster.
