My turbo project
Ive always wanted to turbo my car recent cars and the s2000 is a beast when its boosted lol
anyways im looking at doing a custom kit or used kit.
-Tuners and Shops-
-if you wanna give me a quote or anything on a turbo and everything thats needed with it please pm me
Goals
-make 300whp daily driving
-make 400whp when i race
-rebuild rear end after i install and tune turbo
heres what i wanna do
-buy a manifold, downpipe and intercooler that all fit together. (bolt on)
-currently looking at turbos (reccommend me any)
-im looking at a nice BOV (loud and nice recommend me any)
-what engine mangement should i go with? im gonna buy that first.
-If things look pricy i will consider a used turbo kit.
-I wanna install and learn everything.
-Im a lil cheap on things but i have to do this right
Other
-post any websites that are awesome
-Once i install it i will post pictures.
Thanks for Looking
-Zach
-Tuners and Shops-
Goals
Other
Thanks for Looking
-Zach
Cheap = never equals reliable power.
Look into VTECs2k's kit.
I think you should probably buy a IP kit, you will have good results and easy install
Since your an 01, i suggest you get the AEM EMS 1052/6052
For engine management I would go standalone. If you have emissions in your state you probably should go K-Pro as it will "pass" the OBDII Diagnostic test whereas the AEM EMS will not.
I have the ultimate racing kit and make 310whp at the base wastegate pressure of 8psi.
You will need a new clutch.
You should also get gauges to monitor at least:
Wideband O2 sensor and Gauge to monitor AFR
Boost
Oil Temp
Oil Pressure
and if you get an EMS then you will need a water temp gauge as well.
Obviously this is not in-depth info at all, but my best advice is this:
Decide what exactly what kind of turbo setup you want (power, transient response/lag, mid-range, max power, etc)
Research and pick a kit that meets your needs.
Find a good installer/tuner even if you have to go a little farther to do so
DO NOT CHEAP OUT. Inevitably, the part you cheap out on will be the one that fails. Failure with FI can be very expensive.
Boost
Oil Temp
Oil Pressure
Originally Posted by TurboR,Jan 7 2010, 02:06 PM
I think as right now, Mase's full turbo kit, comes w/everything for $6500 pre-tune, pump gas around 400whp+. Best bang for the bucks.
Mase 904 268 3001
Mase 904 268 3001
Originally Posted by JspecVtec,Jan 7 2010, 02:28 PM
its not $6500 anymore is it? i think its $7000+ now..
Mase's must change price recently, i'll ask him price next time i talk to him.
