my turbo is toast!
Old Sep 21, 2015 | 07:10 PM
blixhavn's Avatar
Originally Posted by spectacle
Originally Posted by blixhavn' timestamp='1442371752' post='23748103
That being said I would like to have full spool by 4500 rpm, power goals 450 for street/pump gas 94 octane, 600ish for 114 octane.Keeping the whatever brand is better than this brand jabber out of it, what would you recommend for a turbo. The quicker it spools the better.
lol 6266 is too big, maybe if it was a drag only car
What kind of car are you building then? You need a 62mm+ size turbo for that goal if you don't want to max the turbo out on race gas.
It's a car with a confused personality lol. I work a odd hours job that makes it very hard for me to get to lapping days, which results in me being able to make around 3 lapping days. As much as I want the car to be built for cornering and snappyness. It sees the majority of its use in spirited driving on the streets. I do go to the drag strip as well but I'm not really concerned about times too much over there cause I don't have a beefy trans yet, and it's really just for fun. Plus I don't feel like adding a 5th or 6 point in my cage to go below 11.5. They are extremely strict at our drag strip and kick anyone out that runs below 11.5 without being in cage rules.
So with that being said, the car will see the high boost tune pretty rarely. The reason I say the 6266 is too big is because the one dyno sheet I've seen of it, it looks like it comes in at around 5000. Mind you that was a F22 and countless other variables. But the more I read the more the .82 hotside of a 5862 or 6262 scares me of "choking out" on the twinscroll manifold I have. Do you think it's really going to be that much of a issue at 400 to 500 hp? So the 6266 looks a little more appealing in that aspect. And to boot it I have a buddy with a very lightly used one for sale off his drag civic. It's a gen 2 and has a 1.15 hotside, and I could get it for 1200$.
So I'm trying to weigh my options between the 3 options. 5862 seems like it would be best the best option for my spirited driving and track. 6262 looks like it would pretty much be the same with a couple more HP but 300-500 rpms of more lag? The 6266 gen 2 seems like it would be a little more geared to the drag strip but probably wouldn't be too terrible on the street or track. I'm not opposed to the 6266 I just dont want it to be ultra laggy, 5000+RPM coming out of a corner. Do you think that it would be too much for my needs on low boost? (450 whp)
Old Sep 21, 2015 | 07:21 PM
spdracerut's Avatar
And well I'm at it, does bigger AR numbers spool faster or slower?
The GTX3576R pretty much exactly meets your goals.
To answer your question on A/R, read this:
http://www.motoiq.com/MagazineArticl...p-Details.aspx
Old Sep 22, 2015 | 04:25 AM
spectacle's Avatar
If you're not going to run race gas for any significant amount of time or go for real numbers on the drag strip, stay in the 55mm-58mm range and run the biggest hotside you can. For the street, something like a 5558 or the 5858 would work great for you.
Old Sep 22, 2015 | 09:54 AM
blixhavn's Avatar
Thanks for the input. If the biggest hotside I can get is a .82, is that going to choke it out on top end on a twin scroll? Or should I be searching for a bigger hotside than that? (if such a thing exists)
Thanks for the help, I'm new to this turbo stuff so it kind of confuses me. And reading everyones opinion on a forum doesn't help sometimes lol.
Old Sep 22, 2015 | 10:08 AM
baZurk's Avatar
Originally Posted by spectacle' timestamp='1442924712' post='23754251
[quote name='blixhavn' timestamp='1442891400' post='23754043']
[/quote]
Looks like Precision has a new turbo out. The 6062 is available with a divided t4 .84 a/r hotside. And it is in the Gen2 family so it should be a reliable turbo from what I have seen. You could give that a try. The hotside is a little small for a divided housing, but that will allow for a quicker spool. The 60mm compressor will also be able to reach the power level you want without any problems. The 5558 and 5858 are not available as Gen2 turbos last time I checked.
Old Sep 22, 2015 | 01:52 PM
blixhavn's Avatar
Thanks bazurk, definitely been looking at that one too. Didn't realize that the 5860 wasn't a gen2.
Old Sep 22, 2015 | 05:38 PM
spectacle's Avatar
I wouldn't run that small a housing on a divided manifold. It will choke a lot up top.
Old Sep 24, 2015 | 03:50 AM
blixhavn's Avatar
well it's the biggest twinscroll for that size of turbo by the looks of it, why would precision make it if it wasn't going to work?
Old Sep 24, 2015 | 05:37 AM
spectacle's Avatar
I didn't say it wouldn't work, I said I don't recommend it. Do some research on divided housing setups on F20/F22's. Most people have issues with flow on the top end.
gfresh86
Jan 10, 2017 09:51 AM
g.guess88
Apr 3, 2015 02:13 PM
lude92_si
Jan 5, 2014 01:31 PM
Tyraid2K
Dec 1, 2006 07:11 PM
lwp
Jan 2, 2005 05:17 PM
