My Unicorn Build
Old Jun 8, 2012 | 02:48 PM
  #21
wildkart's Avatar
Originally Posted by 08s2000CRbackinblack
nice setup!!! i got a custom intake manifold from john with a custom intake manifold plenum and a slight port/polish on the stock runners, since you already on good terms with him id see if he could do a good deal for you. he does some nice fabrication
check it out!
https://www.s2ki.com/s2000/topic/814...#entry19466974
Yeah, the intake is the next thing that I will do when i get some extra cash together.. I still have to get the car tuned first.. 1 step at a time.
Old Jun 8, 2012 | 02:53 PM
  #22
manny-s2000's Avatar
Looking good man. You did well for a first timer, although I can see you had all the helP you needed in for some dyno #'s
Old Jun 8, 2012 | 03:08 PM
  #23
wildkart's Avatar
Thanks. Yeah John built the motor, I did the install of the motor, and transmission, clutch and everything. Got the car running on the stock ecu and injectors, then John did the turbo setup.
I want some numbers too, Just in the middle of moving at the begining of july so trying to get the money together to tune the car and move is kinda hard.. It will come soon enough.
Old Jun 8, 2012 | 03:31 PM
  #24
herecomesboost's Avatar
The more I see the red dash, the more I like it.
Old Jun 8, 2012 | 03:48 PM
  #25
vduber's Avatar
Looks good you and me have very similar builds an goal. Can't wait to see numbers props for running the clutchmasters stage 4 6 puck I'm running that too
-Chris
Old Jun 9, 2012 | 06:44 PM
  #26
wildkart's Avatar
-Chris
I cant wait to see numbers either.. how do you like the 6 puck?
Old Jun 9, 2012 | 08:06 PM
  #27
vduber's Avatar
Haha once the cars running I'll let you know my motors currently finishing being built. I've heard awesome things about it though a bunch of my friends swear by them. Hopefully my car will be done in a month or so work has jut slowed my build so much. Good luck though
Old Jun 11, 2012 | 06:23 AM
  #28
wildkart's Avatar
Thanks, you too..
Old Jul 7, 2012 | 10:04 AM
  #29
wildkart's Avatar
So I figured I would post a quick update.
We tuned the car on Tuesday and it made 490WHP on 93.. Not bad, but we could no tune for race gas as my fuel pump was maxed out. So we got it off the dyno and Alpha took it for a test drive to make sure everything was good and it was great he said. checked the oil everything was fine. So I went to leave and got a block down the road and threw all the oil out of the motor..
Turns out that the oil filter relocator on the side of the block came loose somehow, even with locktite on the bolt. and pushed the gasket out the side. We are in the process of getting it fixed and hopefully we did not damage anything from the short run. We came back and there was about a court of oil still in the motor and it turns over free. so we will see what happens after we get the new seals in.
Old Jul 7, 2012 | 04:45 PM
  #30
Torque Obsessed's Avatar
Oh man, sorry to hear that... Hope the motor is ok.
