N1200 vs N1500 final verdict?
So I’ve looked on the forums for info on the N1500, and read whatever info was available but still can’t come to a good conclusion. I have both blowers available, and planning to upgrade the bearings to spin the blower to 60k using a 3” RR pulley (possibly upgrade the impeller). So my question is which blower should I go with? I’m aiming for 500+++ whp on E85. Also, is belt tightening much easier on the SOS vs Comptech kit? I have both kits available for the install, debating which one to keep . Thanks in advance!
-AP1 w/ stock engine 68k miles
-DW 1250 injectors
-FMIC
-Walbro 450
-CT header
-70mm exhaust w/ TP
-Ported intake mani and TB
-DW 1250 injectors
-FMIC
-Walbro 450
-CT header
-70mm exhaust w/ TP
manolo1492 (12-08-2017)
Mate I have a brand new polished 1500 Ti Supercharger, never used. Comes with all new Vortech mounting plates and custom 8-Rib pulley set up with SOS Racing Heat exchanger and mounts etc... I also have the Cobra water pump.
My set up is identical to SIDEWAYS member on here.
You can have it for $2500
Novi 1200 RPM: 52000PSI: 22CFM: 1150HP: 775
Novi 1500 RPM: 55000PSI: 26CFM: 12000HP: 825
Yeah I've seen a couple cars get to 500whp with the N1200, but I'm wondering if the N1500 would be better for the job and maybe get there a little easier? Some of the comments I had seen previously regarding the N1500 stated the the blower was less efficient than the N1200 to 1150cfm or something like that, but where is this info coming from? I still haven't found any flow maps/charts that illustrate flow or psi per given RPM on either blower. So based on the specs below, is there a reason NOT to use the N1500? I have both blowers sitting on a shelf in my garage btw.
How about getting a 2200R Novi and make some power? The smaller blowers are very limited. A good 8 rib pulley set-up will make it all possible.
Sideways (Phil)
I am selling my Novi 1500Ti Model Supercharger Kit with 8-Rib Pulley set up. it's all brand new and identical to yours as you know.
Do you know anyone who would want to buy this?
gary_phd
12-04-2005 07:06 AM
