Navy_crx's Turbo build
Old May 19, 2012 | 06:09 PM
Navy_crx's Avatar
Default Navy_crx's Turbo build
So ive been a troll around here for a while so its time to start my own build thread.
Started off buying my 2000 GPW AP1 for 5k 2 years ago, i was test driving it and an axle broke (not my fault i was still in the parking lot i met the guy in). Well a long story short he thought it was the diff so i got it for half asking price. turned out to be a broken axle and an easy fix. well fast foward 3 months when i had an overheating issue and popped the HG and scored up #4's walls pretty bad. dident know this till after my 7 month deployment so it sat for a WHILE. i finally got stateside and pulled the valvecover to find this
off went the block to Laskey for a 10:1 pauter rod, CP piston build while i ordered all new OEM parts for the botom end, and started my shave and tuck.
Old May 19, 2012 | 06:10 PM
Navy_crx's Avatar
while i was doing all of this i recived a package in the mail
Navy_crx's Avatar
then i had to decide on turbo stuff and well at this point i have to be honest i was running out of money so heres the turbo stuff
Old May 19, 2012 | 06:11 PM
Navy_crx's Avatar
Well after all this it was time to put the motor in
she sat for the last 2 months and i finally got to put some time into her so as she sits today(yes i know its dirty will be cleaned as soon as i get her home)
Want to know everyones thoughts
still to go
ID2000's
IE dual 044 surge tank
oil scavage pump to valve cover
catch can
Navy_crx's Avatar
if anyone wants more pics please ask as i have hundreds!!!
Old May 19, 2012 | 07:28 PM
hatchbone's Avatar
Looking good,real nice job on the tuck/ shave job
Old May 19, 2012 | 07:34 PM
Navy_crx's Avatar
Thanks it was my first shave/tuck i really dont know if i would do it again. She's in primer now and will be for a while as i cant afford a good paint job and getting her running is #1 on my list.
Old May 20, 2012 | 04:00 AM
XBMAX's Avatar
amazing
Old May 20, 2012 | 05:02 AM
s2knoob89's Avatar
Looking good so far I wouldn't wrap the manifold. Theres nothing to melt since you tucked everything.Quality of the manifold is still unknown and it may start to crack. Any reason your using a scavenge pump instead of just running the drain to the timing cover or pan?
Old May 20, 2012 | 07:05 AM
Thunder-rush's Avatar
I think gravity will help your oil go back to the pan. No need for scavenge pump at that turbo location. Even though the manifold is from a reseller on ebay I think the quality seems to be up par with more expensive offerings, at least the welds on your unit looks ok. for sharing your story.
