need opinion on what to do with head
Check your vtec screen for shavings, that will tell you if the bearings got beat up.I've seen this happen a couple times but it was always on anti lag, the aluminium head heats up faster then the steel plugs.they are not in there very tight to began with so it don't take much to push them out when the head heats up, I doubt the head lifted I run the fbm studs and they are solid units, still can blow a head gasket though, regardless of studs imo
I pulled the head off and found nothing wrong with the head gasket...how ever i found this on the fbm head studs
not sure what to think of it since all studs screw back in with no problem..what do u guys think?
