Need some approval from pros
Old Dec 18, 2006 | 03:37 AM
S_NeWb's Avatar
thx. i think i might that help manual.
Old Dec 18, 2006 | 09:05 PM
S_NeWb's Avatar
would this set up work?
if not.....
"You can remove the 2 hoses from the EVAP purge and use these for WG and BOV. No T's required. You can only do this because you are using a EMS. Stock PCM cars need these hooked up. "- slows2k.
if i unhook these am i suppose to seal up the connection intake manifold or just leave them open? i mean the 2 Evap purge hose i unplugged.
Old Dec 20, 2006 | 06:12 PM
Slows2k's Avatar
Remove the T you currently have. Remove the hose, and hard pipe that goes to the fitting next to the PCV valve line, and the other fitting behind the throttle body.
With the 2 open fittings you now have, run 1 line to you BOV. Run the other to the WG.
Old Dec 20, 2006 | 06:32 PM
S_NeWb's Avatar
when i remove the hard fitting and behind the throttle body. it wont leave an opening in the intake manifold?
Old Dec 20, 2006 | 07:05 PM
Slows2k's Avatar
It would, but you can use that open fitting to run either your WG or BOV
eastonh477
Feb 4, 2014 08:12 PM
d-bo
Feb 28, 2013 03:59 PM
jdmdc529
South Florida
132
Nov 14, 2008 10:58 PM
Red_Devil
Dec 26, 2006 12:32 PM
luckistryke
Mar 16, 2004 07:44 AM
