New to boost and looking for some tips
Old Apr 12, 2013 | 02:30 PM
obriener2054's Avatar
what i had in mind was a hondata? i thought i read somewhere they are 3 bar?
also i just remembered colder plugs, what are people running over the OEM ones
in Ireland, we mostly have 95 Ron, but we have a fuel that is percentaged bioethanol and runs at 99 or so....... ( we used to have 85% ethanol at 0.99c a litre but the goverment taxed the hell out of it, bas***ds )
i said i'd go with the 12psi and leave it at that, i already run a modified Accord Type R so i can't be silly in that respect
Old Apr 13, 2013 | 12:56 PM
what do people think on the plugs??
NGK Iridium IX - BKR8EIX ?????
Old Apr 13, 2013 | 05:20 PM
Manny2587's Avatar
Those will do fine.
Sent from my iPhone using Tapatalk
Old Apr 14, 2013 | 06:35 AM
1SlowSi's Avatar
Here's a tip... Do it right the first time with parts that somewhat exceed your goals because mark my words...you will want more power eventually. If you ever have to second guess yourself on whether or not to spend extra money on the part you truly want, spend the extra money. It happens to all of us.
Old Apr 14, 2013 | 01:58 PM
That's where I was thinking... Go for the 12psi and leave it at that.... It's not my daily by any means but I don't settle for second best , hence the thread!!
I only have done 4,000 miles in 2 years .... Just fancy building something special not seen over here !!
Old Apr 15, 2013 | 02:04 PM
s2konroids's Avatar
+1
Old Apr 17, 2013 | 06:53 PM
so i'm going to go with this 3 bar map sensor also
http://www.scienceofspeed.com/produc...r/00-05_S2000/
if running 12psi, would it be advisable to upgrade the heat exchanger and then the water pump also??
to one from Science of Speed ($400)
then there's this option which i'm swaying to
https://www.s2ki.com/s2000/topic/913...eat-exchanger/
any help appreciated
Old May 15, 2013 | 07:55 PM
found these
http://www.ebay.co.uk/itm/260334999430
do they have to be gapped thereafter or are they set-up ok?
also am i mad paying 99$ for an SOS map sensor, will another one cheaper do the job just as good?
Old May 16, 2013 | 02:04 PM
Muggus's Avatar
Your stock exchanger should be fine. Mine stays ice cold. However i have yet to test it in the summer heat.
Old May 21, 2013 | 07:45 AM
thanks for the info......
it arrived today so i will get through it and see what parts i exactly need as there's a posibility it may be just the fuel pump
Jjnormanyale
Jul 1, 2013 01:41 PM
bobonacus
Mar 5, 2012 07:45 AM
spapdx
Aug 11, 2011 03:10 PM
Marklee77
Oct 4, 2010 02:29 AM
S2Kart
Apr 2, 2008 05:37 AM
