Boost and Non-Boost Map?
Old Apr 1, 2008 | 11:16 AM
S2Kart's Avatar
Default Boost and Non-Boost Map?
Question: If I want to have control of ignition timing and injector while not boosting, (as well as when in boost) can it be done with an Emanage ULT? I don't think so but I don't know. If I just I extend the operating range of my existing inj and ign maps, they will surely be way too coarse. Seems like I would need to be able to call up two sets of maps, real-time.
Otherwise could I do this with an AEM 1052? If so, is it one big injector map and one ign map, or are their two maps for each (4 maps total)?
-thanks
Old Apr 1, 2008 | 02:52 PM
WLAURENT's Avatar
Yes - you can with the ULT
Old Apr 1, 2008 | 03:08 PM
Soul Coughing's Avatar
on ems you have a vacuum and positive pressure on the chart. with fuel and ignition maps accordingly
Old Apr 1, 2008 | 03:51 PM
AusS2000's Avatar
You can do it with any of these set ups.
When you aren't in boost you are just using the lower portion of you map.
Old Apr 1, 2008 | 04:30 PM
S2Kart's Avatar
Thanks guys, Now for the ULT, I was guessing that a 16X16 map would become to coarsely divided to span the full Map V range? Am I wrong? Or do you use two maps - one below Map V clamp and one above (in boost)?
I'm confused . . .
Old Apr 1, 2008 | 04:39 PM
AusS2000's Avatar
Below boost your stock ECU handles it with no correction required from the Ult.
Old Apr 1, 2008 | 04:42 PM
WLAURENT's Avatar
You could use "I/J Adj Map 1" and "Ignition Adj Map 1" for out of boost and then use You could use "I/J Adj Map 2" and "Ignition Adj Map 2" for when you are in boost. Would give you a 16x16 map for both in and out of boost. I currently leave everything on my car below 0 psi to the workings of the ECM and use the Maps to tune in boost.
Old Apr 2, 2008 | 05:37 AM
S2Kart's Avatar
Ok I think I got it, thanks. Right now my stock ECU handles the out of boost, and its all fine. I'm poking around at some other stuff whereby I would want to tweak the out of boost inj and ign just a hair - I'l give it a try.
Jayboy83
Jun 16, 2013 07:40 PM
seansniper
Oct 3, 2012 11:56 PM
mr_grand_prix
Dec 6, 2007 01:01 PM
MB
Sep 30, 2005 11:15 AM
Gernby
Nov 25, 2003 12:29 PM
