New BW turbo options
Old Nov 6, 2013 | 07:02 AM
  #41
passmans2kny's Avatar
Originally Posted by Brady1988
BW continues to amaze me! This new 300sx sounds like it's gunna be the
best street&strip turbo out there. Kindasorta bridging the gap between the 62mm 300sx FMW and the 67mm 400sx FMW!
yup this new 64mm one is gonna be a very popular option
Old Nov 6, 2013 | 03:40 PM
  #42
d-bo's Avatar
Originally Posted by ScorpionT
Originally Posted by d-bo' timestamp='1383615526' post='22861920
cool i just realized you're the same person i have been talking to on evo-m Lolso is this the turbo we have been talking about ?
Nice to see you over here. This S300SX is different, its a factory built turbo from BW with a 64.5mm compressor. The one you and I talked about has a custom compressor upgrade.
Originally Posted by beaudin223
s200sx and s300sx gona be all journal bearing ? they are oil cold and water coled ?
Only the EFR line are ball bearing/water cooled.
which one would you suggest? I would be looking for about 800-850hp spool is important but i would sacrifice a bit of spool to not have to run 40psi to make those numbers
Old Nov 6, 2013 | 06:57 PM
  #43
sounds like that 64mm new hotness is calling ur name for those power goals
Old Nov 7, 2013 | 09:04 AM
  #44
ScorpionT's Avatar
Originally Posted by ScorpionT' timestamp='1383679339' post='22862994
[quote name='d-bo' timestamp='1383615526' post='22861920']
[/quote]
The 64.5mm could theoretically make power in that range, but would be very near the edge. If you want more reliable power I would go with the custom 66mm because it should be good for ~900hp.
Old Nov 7, 2013 | 11:17 AM
  #45
d-bo's Avatar
Originally Posted by d-bo' timestamp='1383784846' post='22865303
[quote name='ScorpionT' timestamp='1383679339' post='22862994']
[/quote]
[/quote]
Is that a 4.21 flange ? Or is a 3" stand vband an available option for him to do ?
Sent from my iPhone using Tapatalk
Old Nov 7, 2013 | 12:35 PM
  #46
ScorpionT's Avatar
Originally Posted by ScorpionT' timestamp='1383847465' post='22866518
[quote name='d-bo' timestamp='1383784846' post='22865303']
[/quote]
[/quote]
[/quote]
It comes with the 4.21" and thats what I recommend using. The turbine wheel has a 74mm turbine exducer so when using a 3" modified outlet the expansion area after the outlet would be very minimal which impacts performance. Not only that, but modifying the housings isnt safe and it can lose its burst containment capability. It works fine with the smaller 76m wheels but for the larger 79mm I dont recommend it.
Its also possible to get the 66mm wheel with the smaller 76mm turbine so you can have the housing modified with the 3" outlet, but it just adds to the cost even more.
Old Nov 8, 2013 | 11:25 AM
  #47
camuman's Avatar
Originally Posted by passmans2kny' timestamp='1383329101' post='22857462
awesome, the airwerks line is gonna become super popular then, especially with them being journal bearing and realiable
They are definitely a bargain.
Originally Posted by camuman
I wanna see what it does on pump gas.
You could always be the first here to do it!
Old Nov 10, 2013 | 10:51 AM
  #48
flexer's Avatar
Garrett also just released a new version of the GT40R call the GTX40/88R. Will be very comparable to the new borg warner turbo and the 6466.
Here is an article I found on it: http://www.enginebasics.com/Advanced.../GTX4088r.html
Old Nov 10, 2013 | 06:31 PM
  #49
ScorpionT's Avatar
Im still looking forward to the results. If I have time I might test it out myself just to see how it does, otherwise I will wait for the results from a shop I know has a bunch on order.
Originally Posted by flexer
Garrett also just released a new version of the GT40R call the GTX40/88R. Will be very comparable to the new borg warner turbo and the 6466.Here is an article I found on it: http://www.enginebasics.com/Advanced.../GTX4088r.html
Ive been waiting for that to come out. The GT40R performance has always been a bit low and Ive never been a fan of the turbo, but the new compressor should do the trick. I think it will be a great alternative to the 6466.
Old Nov 10, 2013 | 06:44 PM
  #50
d-bo's Avatar
for the price of a super94 (3794) from FP i would probably take that rather than the gtx40r
it seems anything larger than a gtx35## is outclassed by the other competitors
