new Kraftwerks kit OWNER!
Old Jul 14, 2014 | 02:08 PM
Nik2k's Avatar
Default new Kraftwerks kit OWNER!
Hi people! i just buy new kraftwerks kit ! waiting arrive to argentina! i have full bolts on in my AP2 including bc stage 2 cams. i was thinking to buy Magnus intake manifold, my question is what you think of this manifold??? it will help ???? thanks a lot !
Old Jul 14, 2014 | 07:10 PM
Nik2k's Avatar
nobody? please! opinions people!
Old Jul 14, 2014 | 07:40 PM
iDomN8U's Avatar
I don't even think Magnus makes a intake manifold anymore. It's been a while since I last asked them but at the time it was a prototype and really never took off.
I know there are a few othes (kings performance, maybe urge) that make one.
I personally don't think it's needed unless you're making big numbers (500+) but you can't go wrong with just porting the throttle body to 70mm an maybe taper down to 67mm. Have the intake manifold machined to match the tapered end.of 67mm. This will give you a Venturi effect
Old Jul 15, 2014 | 05:40 AM
Jmays2k's Avatar
You don't need it for a Supercharger. I doubt it will add enough to make it work it and may even hurt the overall performance.
Old Jul 15, 2014 | 06:21 AM
Redline S2K's Avatar
If you really want an intake, I'd contact Urge or Fullblown, Urge if I had to choose between the two.
Old Jul 15, 2014 | 07:17 AM
iDomN8U's Avatar
A lot of people will disagree with you. But without Dyno proof, you could very well be correct.
N/A make 5-8 HP from it. I could only assume that SC would make 10-15 HP (not including the delta it affects)
Old Jul 15, 2014 | 07:58 AM
Nik2k's Avatar
thanks readline! you think it will be a change with this manifold?
Old Jul 16, 2014 | 04:58 AM
Brutus's Avatar
Depending on the raw cost/benefit of doing an intake. I suspect money would be better spent on good brakes and tires.
Old Jul 16, 2014 | 05:03 AM
bruthaboost's Avatar
If you're chasing power, you will get more return with a water/methanol kit, fail safe, and smaller pulley to take advantage of it than the intake manifold.
Old Jul 16, 2014 | 10:18 AM
Nik2k's Avatar
water/metanol its good! but smaller pulley in the new kraftwerks kit? wat i read it CANT put another pulley to this kit.. or i conffuse?????
