nitrous?
Originally Posted by directportjuicedS2k,Jun 16 2009, 05:41 AM
I'm running Zex DP, it's easier to install without the hard lines but you need to buy these blue elbows in order for the zex kit to fit in our car if you go direct port, they ran me about $120 all together for 8 elbows.
That setup is clean as! so is SC-Suzukas but he is using the hard lines?
how much was the extra 10lb bottle? did you have to buy anything else to hook it up?
if i buy the direct port kit from zex all i need are the 4 45deg elbows and 4 90deg elbows right? the rest of the fittings come with the kit already?
also last question did you find any problems with fuel pressure drop due to the kit drawing fuel from the existing fuel line?
thanks for the pics too theyre awesome
john
john
Yes, all you need to by is the elbows
No problems with fuel pressure drop, SC-Suzuka has no problems with stock fuel pump and 125 shot.
My entire setup and list of all parts, this will help you.
cool thanks!
so your 2nd bottle isnt actually connected is it? do you just switch the bottle opener and heater over when the first bottle runs out?
are the elbow plugs from ZEX or can you just use any brass fittings?
