Nitrous set up on the S2K...
Originally Posted by OGPackin,Feb 24 2006, 10:53 AM
Im running NOS. My car dynoed 213rwhp w/o, and 288rwhp with the juice....
If you dont have the $$ for turbo or SC id recommned NOS. Im having my turbo installed as i type...
OG
OG
I would run a supercharger instead of the Nitrous set up if I thought it was worth the $5K. To me, it isn't... but that could change after I try the nitrous out for awhile.
Originally Posted by HybridHatch88,Feb 23 2006, 10:31 AM
It's actually Nitrous Express and the only Honda motor it works with are B series motors. No love for the F series
Originally Posted by quickysrt,Feb 27 2006, 09:47 PM
nice thread may consider running a direct port to help spool a bigger turbo
how much does it take($) to fill a 5lb botle? how long can a 5lb bottle last?
It can add up pretty quick if you're spraying all the time. But as I'm sure you know, it's illegal to run nitrous for street use, so you shouldn't have it engaged on the street at all. My plan is to take out the bottle unless I'm going to the track, or at the very least have it closed and disarmed. Not only will that reduce my temptation to spray on the random street encounter, but it'll save money as well.
Bump up to the top...
I've decided to go ahead and take the plunge. I know it isn't a popular setup, but I'm going to run a 50 shot wet kit on my S2000, taking every precaution that I can think of to make it safe.
I'm going with an NX kit, window switch, arming switch, WOT switch, bottle warmer, colder plugs, fuel pressure gauge, air/fuel gauge, purge valve, and blow down kit. I may also pick up a VAFC2 to tweak anything I might need to do. It may be a little overkill on the safety side, but I figure that's better than not doing it thoroughly. Is there anything else you guys can think of that I might need? I'm skipping on a remote bottle opener, because I'll only be using it at the track and it isn't too much trouble to open my trunk and just manually open the bottle myself.
Thoughts and opinions appreciated.
Anyone ever hear of the "Sneaky Pete" Nitrous Set-up, my friend has it in his Acura Integra Type R...But I wanted to know if it was safe for our cars, and if it is an option for the guy who started this thread if he doesn't want to lug around big ass bottles...Just a thought..
only problem with nitrous, in my opinion, it's like a girl. Can be a little moody sometimes and cause problems. (burnt rings, detonation) but i'm no nitrous expert. I have a kit which I'm thinking of selling but who knows. One girl is enough to deal with.
