Nitrous wiring diagram help
I'm horrible with wiring and relays and volts and watts and amps and all that electronic mumbo jumbo. Can someone finish my nitrous set up diagram and let me know what kind of relay or relays I need with the numbers and connect my wires as they should be wired. Let me know if you guys need any readings or anything off any of my equipment. Thanks!
This should work. Substitute trans brake for rpm control use the 30a polar for power and just ground rpm switch to car
Make sure to wire the solenoids + together before entering relay. Wire the -'s together and ground to car.
