No Injector Pulse?
Fuel pump is fine, it primes I can hear it from in cabin.
I found out today I believe the 1052u ECU has shit itself.... Awesome!
Brief summary of todays events...
I took my freiends advice and went out and bought a new battery, thinking it'd run partially flat over the 4wk period and knowing the AEM requires quite a few cranking amps to fire up properly.
ECU still didn't fire up. So I uploaded an older tune from another workshop and tried that, hoping it would work... it too failed, same problem ; so I just re-uploaded the good tune and pulled the ECU out altogether.
However with the AEM in place, a can of aerostart has the car idling fine bypassing the injectors.
I ran home and got the OEM ECU out of storage and went back to the dealership. Car fired up first go, although just a bit rough..... to be honest it sounded more like a 13B than an F20C. Car overfuelled by the time I even got to the street and we had to roll the car back into the carpark & I called another tow truck and sent it home again as the dealership couldn't assist anymore believing the ECU is at fault / faulty.
So before I go out and buy a new ECU (maybe not even AEM) I wanted some other thoughts of what may be wrong?
It has to be my ECU, right? Can't be cam angle sensor or knock sensor if the OEM ECU is running the car (with the Comptech ESM & RC750cc injectors even in place).
Originally Posted by camuman,Jan 19 2010, 12:31 AM
s2k doesnt have a fuel filter, just the sock on the end of the fuel pump.
i would drain the tank, but thats me.
the black canister unit that is part of the fuel pump assembly is the fuel filter.
i changed it and opened up the old one to have a look inside. a lot of paper filter inside that black container. pity i can't find the photo.
prob means u've never changed it b4
Originally Posted by fireball,Jan 21 2010, 08:31 AM
wrong !
u mean #7 in this pic?
as far as i know, there is no service interval for a fuel filter in the car. sooo that must be a nonserviceable part that lasts the life of the car.
and i swapped out my pump for a walbro.
http://forums.s2kca.com/archive/index.php/t-3356.html
and for OP problem, i have heard of the injector driver dieing on aem ems. so send yours to AEM for testing and repair.
http://www.alloemcarparts.com/specials/hon...2000-parts.html
if u crack open that white lid , there is a filter inside the black canister.
an yes it was a little dirty when i disassembled it.
s2kadrenalin: how did they quote u $50 if they havent even seen the problem ?!
-there r other ecu options including autronic (pricy)
