Not going into boost
Old Jan 19, 2010 | 05:21 PM
REVHIR's Avatar
Default Not going into boost
Air/fuel is fine in cruising and in acceleration situations but runs lean on idle. I know its not running on 3 cylinders and i know for sure its not the engine. It has a really raspy sound to the exhuast. I have a cast iron mani, but i am wondering if i got a leak somewhere else. Could it be my waste gate has failed? There is no sign of black, white, grey, blue, smoke what so ever and the car runs fine besides the fact that i will not attempt to boost 1psi. You guys have any suggestions? Thanks a lot.
Old Jan 19, 2010 | 05:37 PM
JustinC's Avatar
wastegate stuck open? missing bolts on the manifold somewhere
Old Jan 19, 2010 | 05:51 PM
Spoolin's Avatar
Sounds to me like the map sensor isnt working correctly. Are you on the stock map and running an emanage? If so, the stock map needs clamped at a certain voltage to work correctly to be able to see boost. When I had the emanage many moons ago, I had the same problem until I realized that my tune got messed up and lost the map sensor voltage clamp. Once that was put back in, it fixed the problem.
Old Jan 19, 2010 | 06:13 PM
spectacle's Avatar
def a leak
myflys2k
Mar 31, 2010 02:23 PM
chad86
May 28, 2009 11:58 AM
S2Kart
Apr 2, 2008 05:37 AM
mr_grand_prix
Dec 6, 2007 01:01 PM
NightStalker
Feb 7, 2006 02:42 AM
