Not tapping the oil pan
Hi guys,
I just installed the gt35r turbo kit and was wondering if tapping the oil pan was necessary? I have it hooked to the oil drain plug instead. Kinda like the comptech SC setup but wanted to know whats the worst that can happen? Thank you!
the oil will get backed up in the return line and eventually ruin the seals on the turbo. it takes a hour or 2 to tap the oil pan. You can probably train a monkey to do it. Just do it right. It is something that is nessecary.
the oil only backs up into the line if your return line is too small or if it's not sloped down to the drain pan properly. every time I've ever seen this happen, the car started smoking pretty much immediately. if you're not blowing smoke the first time you drive it after the install, your return line location is probably fine.
Originally Posted by LilJoe,May 3 2009, 06:03 PM
i run my return line this way and it works just fine. im pretty sure that the greddy kit comes this way as well.
I was at a shop a few months ago, this kid was in there getting his kit fixed because of that. I overheard the owner (his shop did not do the original install) saying that he has seen this happen with a lot of Greddy kits.
Greddy refuses to admit its the problem & will not replace anything.
