Not tapping the oil pan
Old May 4, 2009 | 05:47 PM
  #21
CTECHs2k's Avatar
sorry guys...didnt think the thread would turn out like this, but I got to say. Majority of what you guys are saying is still true, but from all the phone calls I made from tuning shops, it is still recommended. Even some said to tap the block instead of the oil pan....
Old May 4, 2009 | 06:06 PM
  #22
spdracerut's Avatar
Yeah... I was thinkng of tapping the block myself. I don't have good feel for where a good spot would be though; guess I'll just need to rip into the engine.
Old May 4, 2009 | 06:09 PM
  #23
ChefJ's Avatar
I have used the drain pan with a -10 line coming from the turbo the entire time without issue. -10 male fitting in the pan and a -10 female line. Makes draining oil easy
Old May 4, 2009 | 10:59 PM
  #24
LilJoe's Avatar
^ same here plus i have a top mount so my return line is a good deal longer than what the greddy kit has.
Old May 5, 2009 | 12:17 PM
  #25
siadam's Avatar
We can make everyone happy.
I'll continue tapping the pan, others will use the girdle, and some will use the plug.
Girdle > Pan > Plug
Old May 5, 2009 | 03:07 PM
  #26
rob!'s Avatar
Originally Posted by siadam,May 5 2009, 12:17 PM
Girdle > Pan > Plug
nuff said.
Old May 7, 2009 | 07:29 PM
  #27
chad86's Avatar
I tapped my oil pan yesterday, but after getting everything back in I was not happy with the angle it was sitting at (little dip that oil could pool)... So I took it out again today and ended up with this.. I am pretty happy with the final product and I think it will be a lot better than the original oil drain location. I also got a plug for it so if I ever want to go back to NA then I can plug it up...
It did not take that long at all so I think its def worth gettin done..
PS: Thanks to those whom I asked advice
Old May 7, 2009 | 09:31 PM
  #28
CTECHs2k's Avatar
Old May 8, 2009 | 05:55 AM
  #29
dsddcd's Avatar
Looks Great, see it wasn't that bad
Old Aug 21, 2009 | 12:34 PM
  #30
Kyushin's Avatar
Banned
So the higher up on the pan is the best place to tap? With the Comptech setup, if I install an AN fitting above the drain bolt, this should be optimal?
