Notice some smoke out of tailpipe
Old Oct 14, 2008 | 07:22 PM
S2k_RN's Avatar
Default Notice some smoke out of tailpipe
So after a recent local drive. Some members noticed some smoke (some say blue tint some say white). It's mostly seen during hard acceleration/WOT when I get into boost (possibly earlier?) But it's only a poof of smoke then according to my friends no smoke after. I also notice that every once and awhile during drives that I do get a poof of smoke when I take off the line (which I've seen personally as light blue whitish tint)
Any suggestions? The blower has about 5k. Do I need Kranvents? Any help is greatly appreciated.
Thanks
Old Oct 14, 2008 | 09:26 PM
57udl3y's Avatar
i have the same problem but i'm stock and white smoke comes ou
Old Oct 15, 2008 | 04:29 AM
2big4aS2000's Avatar
restriction on oil drain? sharp 90 fittngs are a no no, and a welded fitting in the highest part of the oil pan is best.
Old Oct 15, 2008 | 06:16 AM
S2k_RN's Avatar
I'll check the oil return line. Its the stock oil return line that comes with the CTSC kit. I'll check if there's any kinks.
Old Oct 15, 2008 | 06:29 AM
05TurboS2k's Avatar
Mine started kinda like that....and then got bad within a couple weeks.
now cylinder #3 shows 150psi instead of 200-228psi
Let's hope it's not like mine. Do a compression test for the hell of it...and perhaps a leak down test if you don't score at least 200psi across the board.
-G
(better safe then sorry man)
Old Oct 15, 2008 | 06:55 AM
S2k_RN's Avatar
Thanks for the suggestion 05turbos2k I just did one last week. I'll check again soon. Hopefully that's not the problem.
Old Oct 15, 2008 | 08:09 AM
05TurboS2k's Avatar
if you did it last week I'd bet 95% your still fine now.
calcal
Jun 22, 2009 09:26 PM
RangOs2000
Dec 28, 2008 07:14 PM
Blacknizzle69
May 30, 2008 01:34 AM
nMeOnE
Mar 15, 2008 07:28 PM
s2konroids
Car Talk - Non S2000
Feb 18, 2007 07:05 AM
