Novi 1200 Oil Feed Question
I am hoping someone on here can maybe shed some light with a dilemma I am facing. So I am installing a new CT-E with Novi 1200 non SL and ran into issue with the oil feed line. In the past with my Novi 1000 and from all the picture I have found the oil feed line is up top, but on my new kit the oil feed is down close to my drain line. What I wanted to know is this the correct way it is suppose to be?
On my old Novi 1000, you can clearly see the feed line to be up top and the drain down below.
Thanks Boosted_707, So i went mad looking and the best i could find was this picture that i pulled from Ct-E's Facebook which has the feed line down below similar to my kit. I changed nothing and ran it as is. The car is up and running, strong might i say, but still breaking her in.
You can swap the fitting to different spots (I assume to allow the blower to be clocked differently for different applications).
It looks like you have a brass plug on the top of the blower where you should have swapped your oil feed to, assuming I'm understanding your pictures and descriptions properly. When I received my Novi 1200, the fittings were in the wrong spots and I had to swap them. Here's a picture of my feed location using the SOS Novi 1200 adapter plate (the only picture I have at the moment, sorry it's not closer).
Science of speed sells the blower and an adapter plate for the comptech kits to change the blower to the Novi 1200 (note, the plate fitment sucks and you should mock up and grind your belt tensioner so it works properly before installing everything).
It seems like their website was just updated and it's not listed back on it right now, though you could call them and ask.
Do any of you Novi 1200 owners have the oil feed line on the bottom of the blower, next to the oil drain line? All pictures I've seen online have the oil feed line on top of the blower, but mine is located below. If my setup is wrong, does anyone know the torque settings for the oil feed fitting into the blower (and the brass plug into the blower as well)?
ubise
Jul 15, 2010 05:46 PM
XclusiveAutosports
Oct 2, 2006 07:57 AM
