Novi 1500 install
What made you decide on such a lower comp ratio? I'm going a similar direction (stroking to 2.4 and building the block) but I'm not lowering the comp ratio on the advice of Jeff Evans. He suggested I keep the stock compression ratio for a supercharged application, and the only people I know that change ratios, are using 10:1. I don't know anyone here escept turbos with 9:6:1. Just curious what made up your mind?
Will be nice and torquey though
As far as my build, I'm upping displacement through piston diameter, rather then stroke. So with compression ratio aside. I should be increasing hp and trq throughout the stock rev range.
Yeah the 1200 just seems like a better overall, more efficient blower from whats being gathered. I will probably end up with it. I just hope its enough to crack 500whp for me.
Originally Posted by cinaibur' timestamp='1348519689' post='22035011
Hmm... I wonder where that will put me since sideways is 500+ at 9:1 comp. Jeff Evans said I should expect to pick up 10-15% additional power from stroking to 2.4
Originally Posted by s2000Junky' timestamp='1348529751' post='22035389
[quote name='cinaibur' timestamp='1348519689' post='22035011']
[/quote]
With a longer stroked motor, a lower rev limit is typical to insure the engine doesn’t destroy itself prematurely. There are more stresses on a longer stroke engine. The power band itself shifts down in rpm also, so there is a point where it doesn’t make sense to rev higher, though being Supercharged that rpm is likely higher then what is safe for the motor. But Inline pro is cool with 8200rpm on the 2.4? Thats good news for you. I have a friend who is getting a 2.4 tuned soon. I'll be interested to find out where they cap it on his turbo set up.
Yeah I think we all would like to see this, but it is a pretty big investment to risk being disappointed. You know all to well of that unfortunately. Who bought your 1500...and what ever came about with their set up?
