novi2000
Originally Posted by Sideways,Jan 15 2006, 09:56 PM
Check this insight to the procharger.
Also, just because I thought you might be trying to look at all the options, this is the link to the company that makes the original Paxtons still.
http://www.paradisewheelsinc.com
They are the original ball-drive paxtons. If you are cuious what that means, well, it means that instead of the impellor being rigidly driven such as by gears, it is driven instead through the friction of a special 'ball-bearing'. The advantage is that It slips slightly internally and helps prevent the belt from slipping but eventually catches up to full speed and then maintains speed a little better between shifts as it takes longer to slow down to the speed of the engine. They also have self contained oiling and mainteance is changing the oil and occasionally changing the balls as they wear. It's not a bad design. It's been around since the 50's (rare factory option on the '57 T-bird for one) and was popular well into the 90's. Just an idea.
well lady's, it's pretty much a game over for me. i think im goin turbo, or at least a smaller blower. i gave it my all, i just dont think this blower is meant for our car. if any of you know somebody that might want the novi2000, it only has like 10hrs on it, its a $2200.00 blower and i think im gonna go for $1250.00+shipping. im gonna post in the for sale forum but i figured i would explain the situation to you guys a little more. thanks for all your input and advice(asura,black nugget,hukares,sideways,slows2k,ect.) ill explain my next set-up once i figure out what i wanna do.
-blake
-blake
I don't see how crankcase pressure will build in the SC, Comptech uses a oil return line than alwas has oil on the bottom, and oil is sprayed in from the top. It's effectively sealed from the crankcase.
sscott0203
Jan 8, 2011 10:42 AM
