Oil Choice
Old Jan 28, 2013 | 04:07 PM
  #91
riceball777's Avatar
My car use to burn over 1 quart per 1000 miles with mobile 1 10-30
I know burn less than 1 quart per 3000+ miles with brAd penn 10-40
Old Jan 28, 2013 | 07:00 PM
  #92
redboost10's Avatar
Originally Posted by s2000Junky
Originally Posted by bj@jjautowerks' timestamp='1359400197' post='22298244
About to switch over to Brad Penn, now should i use 20-50, or 10-30? My motor is stock.
10/30. I think 20/50 is too thick and may actually starve your engine of lubrication due to the small oil passages and tight tolerances. If you could find a 5/50 race oil and your FI where higher temps are reached and or tracking the car, then that I might consider. 5 to 10/40 is typically the go to for those applications though.
i always use brad penn 20/50 on fi motors. i like the extra oil pressure and will sacrifice the little loss of hp for it.
Old Jan 29, 2013 | 02:34 AM
  #93
gettin it's Avatar
I think m going to go with 20-50 brad penn then. My motor has 130k on it, and i will be beating on it some.
Old Jan 29, 2013 | 06:54 AM
  #94
Ben @ Carolina Dyno's Avatar
Brad Penn, Valvoline VR1, and Rotella T are all good oil choices for turbo cars. I use the Valvoline VR1 in my track car. I would not use RP under any circumstances.
Old Jan 29, 2013 | 08:19 AM
  #95
TerminatioN's Avatar
I was using Amsoil previously, but decided to switch to 10W40 Brad Penn this last change. Seems good so far. No complaints whatsoever.
I'd guess they are relatively close in performance. However, the main benefit of Brad Penn (over Amsoil) is the price. It is much cheaper.
Old Jan 29, 2013 | 08:47 AM
  #96
bj@jjautowerks's Avatar
Correct, Brad Penn 20-50. Whats the going price per case in your area?
windhund116
Sep 8, 2015 08:10 PM
drl513
Jan 4, 2014 02:25 PM
Trackforged
Dec 2, 2010 12:15 PM
Destiny2002
Apr 19, 2002 08:11 AM
