OIL FEED LINE.. where does it tap into?
Old Apr 8, 2008 | 06:45 PM
HMFIC's Avatar
Default OIL FEED LINE.. where does it tap into?
OK. guys.. as some of you know, i'm installing a turbo kit as of right now and i ran into a snag. what is the best place the oil feed line taps into?
Another snag is, for you guys that run the oil relo kit. I have the one that you screw onto the oil cooler but turbo is there so i cant screw on the adapter plate to the oil cooler and there is NO way it can go on.. SO.. next best thing. take off the oil cooler and just put that plate there.. but heres the problem. what screw can i use that looks like the oem one that holds the oil cooler?
The company i'm doing this for is aware of this.. NOW.. and they showed me a pic of this certain oil relo kit that has the 2 lines going out the SIDE of it. kinda like a sandwich looking thing. you have the block, then the oil relocation adapter with the 2 lines sticking out of it, then you have this Plate that goes on the outside with a screw that goes through the middle into the block holding it in place. THATS the one that i need. Can any one tell me which one that is?
This is Very vital info because this kit i'm doing has to have these things in order to work. and these are the components the kit needs to sell for other and upcoming s2000 folks
Other than that.. everything is great!
Old Apr 8, 2008 | 08:13 PM
dalink's Avatar
I tapped my oil pan, i have an extra if you mess yours up!
Old Apr 8, 2008 | 09:13 PM
PatS4P's Avatar
Banned
first try searching this forum there's loads of info covering this topic
Old Apr 9, 2008 | 02:47 AM
jwa4378's Avatar
^ He is talking about the feed line, not the drain line. Drain line goes to the pan/girdle from the turbo and the feed line is usually tapped into the block at the Oil Pressure Switch that is just below the VTEC solenoid. Most people just use a T-fitting between the sensor and the block, with the supply line attached to the "T" part.
I agree, a search would have helped.
John
Old Apr 9, 2008 | 05:31 AM
HMFIC's Avatar
Yessir! ive searched around pretty well and the 2 locations that im coming up with the most is under the vtec sensor and some place behind the block by the fire wall..
I guess what i was trying to ask is Does anyone have any pictures? because i cant really tell what is meant by the t-fitting and where exactly its it.
Any pics would be very helpful. Thank you guys.. and thanks john for the info mang!
Old Apr 9, 2008 | 07:07 AM
one_slows2k's Avatar
Wassup bro, go to the center of the page for hte pics, you should see what everyone is referring to. This post was very helpful when I installed my vortech kit. Now hurry up n install that thing. haha
https://www.s2ki.com/forums/index.php?showt...0&#entry6638944
Old Apr 9, 2008 | 08:03 AM
HMFIC's Avatar
OOO...MMMM.... GGGG!!!! YOU ARE THE MAN!!
DOOD IT JUST TOOK ME ONLY 10 MIN TO DO!!!
it came with the kit and everything! i was wondering what those peices were for?! hahahaha
I've done my share on DSMS...but this is CAKE!
So much room to play in and everything!
Thanks guys so much for the help!
Old Apr 10, 2008 | 07:42 AM
Jumbalius's Avatar
Yeah glad he showed you the vortech one, that's what i was going to do!!! Glad you got it!
Old Apr 10, 2008 | 05:27 PM
HMFIC's Avatar
THANKS! i'm ALMOST done with the kit. the last piece comes tomolo! so once its one, i just gotta hook up the AEM and have it tuned! and voila!
So hopefully nothing leaks or anything hahaha..but i teflon taped the threads that needed tape, tighted all the nuts and bolts..ect.. so hopefully were good!
goldenfri
Jun 7, 2016 06:37 PM
Ek_Jak
Aug 20, 2015 01:30 AM
Ilike2DRIFT
Aug 24, 2010 10:12 AM
jareds2k
Feb 20, 2005 03:31 AM
