Oil pressure question
Old May 1, 2018 | 02:45 PM
Stevens2000ap1's Avatar
Default Oil pressure question
Hi im running into an issue maybe... im not sure i would like to know other people advice to make my mind.
im running an ap1 f20c built motor for 3 years now, sleeves pistons acl race bearing skunk2 rods studs etc
I run the SOS oil filter relocator and the oem oil cooler
I installed an oil pressure (aem digital) only couple months ago. And here is the numbers:
- cold start 95-100psi
- operating temps 18-20psi
- idle after 30 mins highway, some random pulls 13-16psi
- driving normally at operating temps (3000rpm) 60-65psi
- cruisin on the higher at 65mph ( 4200rpm ) 65-75psi
i hear no weird engine noise. No knock , the engine pulls good. Im just getting nervous since i put that gauge in
Im very worried about my idle oil pressure being so low.. right now i have 5w40 in.
Old May 1, 2018 | 02:56 PM
s2000ellier's Avatar
sounds normal
Old May 1, 2018 | 04:13 PM
tut4u2's Avatar
Active Streak: 30 Days
That looks normal.
If its of any comfort to you, mine drops into single digits while idling after a track session as well. Engine runs and has no issues. I do run an external oil cooler so there's some pressure loss there.
Old May 1, 2018 | 06:47 PM
Im really happy to see that my oil pressure seem normal to you guys.
I know the turbo really doesnt help on cooking oil. I change it very often because im so scared lol
i build this motor a while ago and really dont feel like tearing it appart for a rebuild since the season just arrived here
Old May 3, 2018 | 02:41 AM
RolanTHUNDER's Avatar
COOKING OIL?! Hahahaha.
what brand of oil are you feeding her?
Old May 3, 2018 | 08:17 AM
rrounds's Avatar
What cooks the oil fast on a turbo car is not letting it cool down before shutting the engine down. On my truck with a Cummins N14 putting out 41psi of boost(525hp&1850tq.) I had to let it idle for at least two min, most of the time 4 to 5 min. before shutting it down. Got to cool that turbo first.
ROD
Old May 3, 2018 | 08:18 AM
rrounds's Avatar
double post
Old May 5, 2018 | 05:27 AM
Charper732's Avatar
Those pressures are normal...for worn bottom end bearings. Especially if your oil squirters were removed/plugged
ninetysixyenko
Nov 16, 2016 10:20 PM
Moddiction
Jul 7, 2010 11:27 AM
driftintherain
Dec 10, 2008 08:59 PM
Danyellow02
Oct 11, 2005 09:34 AM
