oil relocation setup?
Old Dec 12, 2008 | 06:29 PM
ChefJ's Avatar
Default oil relocation setup?
Is it possible to purchase the piece of the relocation kit that attaches to the block. I only need that piece as mine seems to have a small leak and won't completely seal properly. Thanks for any info.
Old Dec 13, 2008 | 08:13 AM
HMFIC's Avatar
make sure its not the part that attaches to the block... i thought it was that on mine and it turned out it was the oil lines that were leaking... the thread didnt seem to hold very well... i even used different amounts of teflon tape.. and i ended up getting another one.
Old Dec 14, 2008 | 01:16 PM
ChefJ's Avatar
Thanks. I am in the process of yanking the entire turbo setup and swapping out clutches so I will make sure to carefully check everything that it may be.
Old Dec 15, 2008 | 02:32 PM
berlinas2k2's Avatar
Also, make sure you install the teflon tape correctly. Some people don' know its supposed to go the same direction you tighten the bolt.
Inline Pro oil relocation kit is amazing quality. Well worth the $$
turbodreamz22
Dec 12, 2014 10:57 AM
Suzuka_Joe
Jun 19, 2013 01:44 PM
dsddcd
Feb 23, 2009 11:05 AM
2QYK4U
Dec 17, 2006 03:55 PM
herecomesboost
Jun 8, 2006 08:05 PM
