Oil relocation wont fit?
Old Jun 16, 2009 | 07:13 PM
combats2000's Avatar
Default Oil relocation wont fit?
are we suppose to remove the oil cooler, i know thats basically crap anyways.
(turbo in the way)
what exactly needs to happen to make it work. just remove the cooler? anything else
thanks guys.
Old Jun 16, 2009 | 08:14 PM
dsddcd's Avatar
Yep, you will have to remove the factory OC and place a u-shape peice of hose from one side to the other. You will need the adapter, 90015-PH1-013, from Honda which if you bought a IP kit it already has.
Old Jun 16, 2009 | 10:45 PM
AusS2000's Avatar
Better still, run the water hoses to and from your turbo. I'm assuming it's water cooled.
Old Jun 16, 2009 | 10:59 PM
s_d2k's Avatar
when removing the stock oilcooler and relocating the filter is it necessary to put another oilcooler?
or just leave it like that?
Old Jun 16, 2009 | 11:05 PM
AusS2000's Avatar
Good idea to have an oil cooler. Especially if you're turbo.
Old Jun 16, 2009 | 11:07 PM
I BOUGHT another adapter that will work with the factory oil cooler, well at least i think it will. well c if it does. if not ill remove the factory oilcooler.thanks guys
Marc
Old Jun 17, 2009 | 04:50 AM
DER MotorSports's Avatar
Running an InLine Pro relocation kit?
AlexSobe614
Aug 3, 2016 01:56 PM
Ilike2DRIFT
Aug 24, 2010 10:12 AM
dsddcd
Feb 23, 2009 11:05 AM
otbs2k
Aug 31, 2008 08:56 PM
skibum
Oct 27, 2007 02:56 PM
