Oil feed line for Inline Pro kit is -3an correct?
Just like it says, I need to make sure the oil inlet fittings for the Inline Pro ball bearing turbo kits is -3an as the fitting bolt is stripped and needs replacement. Also, would anyone recommend using Teflon tape on the portion of this bolt that screws into the turbo or the oil feed line for that matter?? Thanks in advance guys!
i dont think you're supposed to use teflon tape for any fitting that screws into the turbo but i could be wrong.
i know you're not supposed to use teflon tape for any earls/AN type fittings, as it could crack them under enough pressure.
Ek_Jak
Jun 8, 2011 06:35 AM
herecomesboost
Jun 8, 2006 08:05 PM
