oil return line leaks
Old Jul 21, 2010 | 03:02 PM
Suzuka_Joe's Avatar
Default oil return line leaks
alright so my -10an braided line for the oil return the line leaks at the bottom where its not sealing up tight like the hose is backing out of the fitting.
can i take it apart, push the hose back down in the fitting and put it back together?
not my pic but the hose isn't seated all the way down into this part of the fitting
Old Jul 21, 2010 | 03:15 PM
juntuned's Avatar
Yes, I would cut the last 1/2 inch off the hose (the mangled part) after you remove the leaky fitting. Then slide the hose further up in the adapter and tighten it. That way the fitting clamps into fresh rubber and has a better seal.
Old Jul 21, 2010 | 04:08 PM
MaseEng Nick's Avatar
don't pull the hose out unless you have to. try to get it to work by just pushing in the hose a bit after you loosen the fittings.
Old Jul 21, 2010 | 04:10 PM
Suzuka_Joe's Avatar
i took the end off and tapped (by smacking it against the work bench) the hose back into the fitting and tightened it down. if it leaks again i'll build a new line. i think it should be good to go though
baldii
Dec 28, 2013 08:18 AM
Deception
Aug 9, 2009 01:14 PM
jwa4378
May 2, 2008 01:23 PM
JoeyBalls
Apr 20, 2008 07:17 PM
Spec_Ops2087
Nov 3, 2007 09:18 PM
