Options to get to 350-400whp
Hey guys,
Had another question for you. So I am finally getting around to installing the SOS Stage 2 Kit. Upgraded the clutch last weekend and started putting the kit on today. Had a question in regards to the BOV. I am not a fan of the stock BPV. I have read on here that all that is needed is a 90 degree elbow/ flange/ and the desired BOV with the correct spring. My question is in regards to the vacuum lines. Does the BOV still connect to the vacuum line with the T connector? And does the port on the original intake just need to be capped?
Thanks!
Thanks!
One last question guys. For the T-Piece connection site. Does the T-piece connect to the vacuum line that goes from the intake to the PCV/Valve cover? or is it a different vacuum line that you use?
You can technically tap into any constant engine vac source but pcv is not it. Tap source off the manifold like for the fpr for example. Plus its usually easier just coming form a source with the same size hose you will be running your BOV with.
Hi guys,
Finally got a chance to hit the dyno! Ended up with 417hp/ 262 trq with stock exhaust (and down pipe) and pump gas on 12 psi. Thanks for all the help and answers to my questions. Next is probably trying to find a down pipe that sounds a bit better. I have an invidia and it sounds like crap. Very metallic ping sound. After that I will probably look for as quiet as an exhaust as I can find.
Thanks!
Thanks!
