Overheating issue...
Old Mar 6, 2013 | 08:35 PM
jordannn93's Avatar
What temp do the fans turn on at with stock switches?
Old Mar 6, 2013 | 08:36 PM
jordannn93's Avatar
Originally Posted by s2kt3
Bleed the system with the front end jacked up ! Til the fans cycle at least twice
Gl
Lee
Is this using the rad cap off method?
Old Mar 6, 2013 | 09:51 PM
franky's Avatar
Originally Posted by OHclassic
Thanks - Yes, all new coolant (anti-f & H20).
* Coolant temp sensor ???
Yes, it's on the thermostat housing facing the firewall. check your fan switch sensor too.
Old Mar 6, 2013 | 10:04 PM
s2000 or 240sx's Avatar
Bleed using the Billman250 method, it takes a while but it is the best way I have used to bleed my system and it gets out the hard to get bubles that form in our sytems. I have a vented hood, mishimoto radiator, oem honda coolant, stock fans, oem fan switch, oem thermostat, water cooled turbo, and a front mount blocking it and cruising at 55mph my coolant temps dont go above 170 degrees on a 70 degree day. I hate to beat a dead horse but bleeding the system correctly is the biggest issue that I used to have mith my s2k and some of my friends s2k's. I hope this helps you out.
Old Mar 7, 2013 | 03:11 AM
OHclassic's Avatar
Originally Posted by wy2slow_z
i got to the point where i didnt trust the bars like you said. that is why i went with a gauge. i went with the hood vents because my car is more for show and driven on nice days only. if your battery and fuse box are tucked, hood vents would be an option. i dont think there are too many people running more than 500 who do not have an aluminum rad. if you can afford the mods to reach that much power then you have enough for the rad! it sounds like you need to bleed it properly as well as find a better combo for fluid imo.
Good points. Yes, have the $ but I want to drive the car and that's been the issue lately as it's been in shop more than driving so I just didn't want to keep throwing $ at it endlessly. Hopefully the AL rad/fluid combo/bleeding will be the end
Old Mar 7, 2013 | 03:15 AM
OHclassic's Avatar
Only have stock temp gauge so can't really tell....need to go on one more drive today to see if fans are coming on at all !
Old Mar 7, 2013 | 04:27 AM
OHclassic's Avatar
Thanks to EVERYONE for their quick and helpful replies. Seems the fans/sensors & AIR/Bleeding needs to be checked ! Will advise if any other issues. Thanks again !!
Old Mar 7, 2013 | 05:56 AM
camuman's Avatar
have you verified the temps in aem when you get 4-5 bars? have you even looked at what temps its reporting back to you? aem v2 drives the dash gauge, but does it drive it just like stock or is it different like the modifry driver?
Old Mar 7, 2013 | 09:16 AM
OHclassic's Avatar
No, have not. All work being done by shop up to this point and just trying to understand. But like I said above, at 5 bars, it is spitting out coolant so I don't think it's just a malfuncting of the light....it does seem to be getting hot.
Old Mar 14, 2013 | 02:11 AM
crb5885's Avatar
I would definitely hook the laptop up and find out at what temps your fan is to turn on and off.
Dstinnet
Jul 13, 2013 06:38 PM
jakub2000
Oct 5, 2005 07:35 AM
ayelien
Jun 3, 2004 12:34 PM
chungtaho0918
Jun 3, 2002 08:05 AM
