PCV Setup
Old Aug 17, 2012 | 10:26 AM
soulicious's Avatar
It's better for the environment.
Just run the front breather and PCV hoses to a breather can. Also, cap off the port on the IM for the PCV hose and gut the PCV. Much better for relieving crankcase pressure. I used to run sealed catch cans and krankvents, but since I upped the boost, my dipstick always popped out. Now, I have no issues when using a breather can.
Old Aug 17, 2012 | 10:43 AM
herecomesboost's Avatar
Originally Posted by SgtDuracell
then would running this to a catchcan be the better option or keep the same two lines to the catch can and have a breather?
Run lines from both the front breather and from the fitting where the PCV was previously located to the catch can. If you simply put a filter on the front breather, it will quickly become saturated with oil (pressurized air will follow the path of least resistance).
Old Aug 17, 2012 | 12:55 PM
SgtDuracell's Avatar
thanks for all the input!
MARK AUS S2K
Nov 24, 2016 03:33 PM
jordannn93
Sep 21, 2012 01:32 PM
EK9MAX
Jul 26, 2009 09:51 AM
ChefJ
Feb 9, 2009 05:35 PM
