petawabit's turbo AP2
cool customizer. I inputted:
flange diameter: 4
base diameter: 6inches ( might be close if you have precision 46mm gates, it's already close with my 5.3inch base diameter of the K&N ru-2510)
filter height: 5 inches ( might be pushing it)
flange length: 1
top diameter: 4 inches
i like the pro guard 7 because it also has entry at the top of the filter. you able to run your cfm calculator on that one?
flange diameter: 4
flange length: 1
uh oh lol. hey, which one would flow more? the K&N with carbon-looking top or the afe customer filter? I'll go out to the car to check over measurements and if the AFE looks like it'll clear, i'll order and should have it to test by next weekend.
ugh, so after looking these might work.
http://www.aemintakes.com/search/pro...?Prod=21-205DK
http://www.knfilters.com/search/prod...prod=RG-1001RD
http://www.knfilters.com/search/prod...x?prod=RC-5060
i am leaning towards the 1001rd because of the inverted top. but still looking.
after using this calculator.
http://www.gnttype.org/techarea/turbo/airfilter.html
looks like the filters that fit are abiout 600cfm. the calculator says i need 650cfm for 14psi. this is all approx i suppose.
Ordered five filters. But part of me thinks I am over thinking this. So as a def I ordered the 2520 As a def use if none else fit.
Calculators say motor needs 600ish cfm but I can't fit a filter big enough to flow that with their calculators. So blah.
I feel the 75a's are great. Really a solid feeling mount that isn't overly harsh like the 85a. The 60a are nice too and feel close to stock, but was recommended the 75a for my application from innovative themselves. Recently got the 75a rear diff mounts and really helped to eliminate the slack that the engine and tranny mounts created in the stock rear diff mounts.
Ordered 5 filters?! Crazy guy. Let me know how it goes. I'll need to check out those specs when I get to a computer
