Pics from my motor
Originally Posted by siadam' timestamp='1308871802' post='20713860
[quote name='Slows2k' timestamp='1308859819' post='20713287']
A vacuum leak under boost will melt piston like that.
Sent from my iPad2 using Tapatalk
[/quote]
It wasn't, making good power per lb of boost. I think I was around ~27lbs for the 670whp #. If it was a leak that bad I wouldn't have made the power.
Chamber temps go up with lean A/F. since you only melted 1 piston, lean in that bore. A vacuum leak is unmetered air, and lean.
That piston melted in about 3 seconds of WOT, from a vacuum leak.
ive melted one piston myself (je piston) and have seen numerous other melted pistons, different manufacturers, all with a hole along the ringlands, all honda engine platforms. and to be honest, most were cyl #3. kinda seems as its a characteristic of honda engines?
our superstock escort with 16.7:1 compression melted a je piston and it was towards the top outter edge of the piston.
where was the above mentioned leak and what cyl was that from?
[/quote]
Not arguing, I would think with a leak and 25+ lbs of boost in the cylinder it would push sir out and be rich, that is what I was thinking ??
Besides, we don't a compression test and all cylinders were within +/- 2psi.
Thats a characteristic of most 4 cylinders in general, cyl 3 is pancaked between 2 and 4. They normally run hotter.
