Plans to Go Stroked and Boosted.
Old Dec 1, 2008 | 02:31 PM
ScorpionT's Avatar
800? Damn. Build the motor, get a turbo kit sufficient for ~400whp with supporting mods. If you drive it for awhile and you think its not enough, upgrade. Better than having 600+ and realizing the lag sucks and its too much power to handle.
Old Dec 1, 2008 | 07:45 PM
Elite's Avatar
if you will be stroking be ready for some headgasket failures when you stroke your block you will bore out your cylinder walls... when you do that you are left with a **** hair of material between each cylinder which sucks when you try and seal the head to the block
what worked for me FINALLY after 3 headgaskets was SCE 2mml COPPER headgasket all my previous cometic gaskets failed all of them between each cylinders.....
but i can assure you i do not regret going with a 2.4l stroked and gt35r
Old Dec 2, 2008 | 07:06 AM
McMuffin's Avatar
Do you have any videos of the car running. Also if you dont mind sharing the numbers you made with me? You can PM me if you like. Thanks.
NYS2000TURBO
Oct 29, 2011 05:14 AM
brendanj85
Jun 23, 2011 08:57 AM
WillS2KI01
Aug 18, 2010 10:40 AM
SPECIAL-OPS-S2K
Feb 22, 2009 09:05 AM
fokissed
Nov 17, 2008 06:15 PM
