PLX gauge ?
Originally Posted by myflys2k' timestamp='1367940325' post='22525046
I had the DM100. AFR, boost, oil pressure. Couple things I didn't like is the screen when top down. I couldn't see what it was reading on sunny days. Also the modules take up quite a bit of space once you get more sensors.
I replaced them with aem sensors and a serial gauge connected to my ems. The serial gauge was definitely harder to set up tho but now I monitor 10+ parameters. I'm also beta testing a Bluetooth module that plugs into the aem ems to read all the same parameters the serial gauge does on my iphone or ipad mini at the same time. It's pretty slick.
The video
http://youtu.be/si0-tRZMPD8
And the thread of the guy that made the device.
https://www.s2ki.com/s2000/topic/100...y/page__st__50
The video
Bluetooth module - Saw that thread and looks interesting....but need something sooner not later. Thanks and hope that becomes a real option in the future
I had oil pressure. Afr. Boost on mine. I was running 14 psi at the time. And the gauge read 5psi peak.... oil pressure was pretty close. 80 cold start 20 when warm.... "close". Afr was the only one that seemed accurate. I bench tested the gauges I have now. They all are very accurate. Its solid piece of mind when you're running lots of boost on a stock motor.
I did forget about the sun with the top down. Seeing the gauges in the sun is really the only complaint I have about the PLX.
I like the AEM gauge aside from the fact that you can only see one parameter at a time and have to switch between them.
To update this a little bit, I just tested plx water temp and oil pressure sensors against its replacement (Greddy D/A).
The only bad thing I don't like about the greddy multi d/a is that everything is displayed metric....but that is easy to get over. I will convert everything for comparison.
Water temp
I have both sensors in an adapter I made that is in the upper radiator hose, near the throttle body. About 8-12" from the oem sensor (which I have rescaled from testing info from this site). The PLX sensor is grounded correctly. I took a random operating temperature and compared them.
PLX 212
Greddy 196
I have my fans set to come on/off at 198/187 degrees, and the greddy gauge reads within 1-2 degrees on and off. PLX gauge would hover around 219/203.
Oil Pressure
Both sending units are in the same distribution block. This was tested at idle, with oil temp in the pan reading 182 degrees.
PLX 19 psi
Greddy 25 psi
It may not seem like a lot, but it is 25% off (if the greddy gauge is correct). I have not tested this at higher pressure yet, so I don't know if it would continue to be 25% off, or 5-6 psi off for the higher range of the sensors.
I had an Intake air sensor as well, and it would usually read 12-15 degrees higher than the oem sensor (scaled) through AEM. I say had because I don't have it anymore. The wire from the sensor fatigued and broke off close to the sensor. The IAT sensor they give you has no connectors....straight from the sensor to the plx module box. Very poor design for a sending unit that screws in (1/8 npt).
I used to like PLX. I've had a few of their widebands (m300) in the past, and never had an issue with them.
Can't say that now....I wouldn't recommend something I cannot trust.
Water temp
PLX 212
Greddy 196
Oil Pressure
PLX 19 psi
Greddy 25 psi
Water temp
PLX 212
Greddy 196
Oil Pressure
PLX 19 psi
Greddy 25 psi
Water temp
PLX 212
Greddy 196
Oil Pressure
PLX 19 psi
Greddy 25 psi
The Kpro reading always seems to rise quickly as opposed to the PLX where the thermostat has to open first before it could get an accurate reading.
Is there a better place to mount an aftermarket coolant temp sensor besides the upper radiator hose?
Oh and the oil pressure.........as I am driving (usually on the highway) my oil pressure readings vary but once in a while it will read zero(for a second, then it bounces back to a reading), and this is while I am accelerating. If I am just sitting at idle it will not read zero. I thought maybe it could be a bad ground? I am not sure what's going on here.....any ideas?
rtboy10
Jul 31, 2016 07:04 AM
Moddiction
Jan 18, 2014 04:40 PM
