Poor Idle and Dying
I installed a Greddy kit recently with the Emanage ultimate and I have had lots of problems with the idle. When the car warms up the idle is ruff and the car dies on occasion if you blip the throttle. The cold idle is great, I checked the fuel trims and they are right at 2% and the wide band is reading 14.7-15 A/F. So I wacked the map, cleaned the throttle body and cleaned the IAC none of which worked. So I am at a loss as to why the car won
Originally Posted by 2big4aS2000,Oct 13 2008, 04:14 PM
turbo causes no vaccum, engine / pistons cause vaccum with tb closed.
They being said, I have adjusted the BOV so that is on its softest setting. I am not 100% but the synchronic BOV may fix this. If it opens under deep vacuum and allows a small amount of air to enter.
The only other thing I can think of is that Greddy did not correctly choose the factory and or aftermarket injector Size and I/J lag time. However the LTFT's at idle and AFR look good. The currently have the following:
Before After
I/J Size 360 560 cc/min
I/J Lag Time 0.1 0.34 msec
Other than that I am lost.
I was having this problem and a whole bunch more.. It ended up being my MAP sensor which had gone bad. A new one and a reset of the ECU and its much better and never stalls.
When the motor is cold though I do still get that low idle and almost stall feel though, but that's only when first driving.
2006ap2
Dec 21, 2009 08:40 PM
