Is it possible to make between 400-500whp and
Old Aug 13, 2008 | 11:48 AM
Riceboi's Avatar
Default Is it possible to make between 400-500whp and
I was just wondering this because it seems like the kits that are carb legal are limited to around 300-325whp (greddy turbo, CTSC).
Right now it seems that Vortech is the only carb legal kit that has the potential to reach high whp levels, do I have any other options?
Sorry if this seems like a dumb question.
Thanks
Old Aug 13, 2008 | 11:59 AM
TRBOKEV's Avatar
NO not legally.
Old Aug 13, 2008 | 12:16 PM
9kFever's Avatar
You can use a CARB legal kit but once you start swapping pulleys, injectors, and EMS you are technically not carb legal.
Old Aug 13, 2008 | 12:57 PM
Vette2K's Avatar
Yes, you can......with an LS7.
Old Aug 13, 2008 | 01:35 PM
Enthralled's Avatar
just look at cars like the GTR...I'm sure it's possible to have a carb legal kit at those power levels, BUT it may cost you a lot of money. end result not worth it IMO!! I'm guessing it's because you live in the wonderful Nazi state of California..you can always get a Kpro or HKS f con if you need to be OBDII compliant. just take it to a small mom/pop smog shop.
Old Aug 13, 2008 | 01:56 PM
ERL_S2000's Avatar
The main going of staying "legal" mean you have no engine codes, and all of your IM readiness codes are set and complete before the Obd2 test. When running a larger fuel system the stock ecu can not control what is being done. On a car that comes factory with a turbocharger, the stock ecu can be modified because you already have a stock ecu that uses the senors needs to control a turbocharger system. Passing all obd2 tests will require no engines lights such as O2 sensor/ main cat/ ect ect. One thing that comes to mind is the K pro software and ecu for the Rsxs that honda makes for the s2000. This should retain obd2 functions and let you be able to turn off the o2 senors since you will be tuning by MAP and Rpm. What are you wanting to do exactly?
Old Aug 13, 2008 | 02:17 PM
Vette2K's Avatar
CARB legal is much more than that. It includes a visual inspection which will obviously spot the turbo, and in turn require the paperwork indicating that the kit is CARB certified. It will then get checked over rather carefully to make sure that the parts that came with the kit, and only those parts, are connected. Anything that has been changed better be damn well hidden. Even an ECU that passes all OBD2 testing will cause a failure if the smog tech decides to have a peek at it.
Old Aug 13, 2008 | 02:44 PM
3ngin33r1's Avatar
As far as oob kits go, probably not.
But your question was is it possible to be CARB legal and make that much power, absolutely. Be prepared to spend a lot of money.
Old Aug 13, 2008 | 04:48 PM
Riceboi's Avatar
Would it be a lot of work to go from a highly modded vortech kit back to a stock carb legal vortech kit in the event of a smog test?
I just want a lot of horsepower and I live california, that's all, and my s2000 would be a daily driver, so I just can't inline turbo it and hide it away or something.
I saw the science of speed supercharger and that really caught my eye, but I doubt it will be carb legal.
Old Aug 13, 2008 | 05:11 PM
3ngin33r1's Avatar
Move.
