Post up your Flex fuel set up
Old May 30, 2017 | 08:08 PM
Smokey Donuts's Avatar
Default Post up your Flex fuel set up
I recently purchased the parts to run my car on E85. I picked up an AEM rail, FPR, ethanol content sensor, fuel pressure sensor I'm just looking to get some insight on how people install their set up (ie: location of the flex fuel sensor, how they routed the fuel pressure sensor.) I already have installed my injectors and fuel pump with proper re-wire. I've been searching on here trying to find some posts or info in build threads but have come back empty handed. Any help is appreciated!
Old May 30, 2017 | 10:06 PM
MorngWoodStewie's Avatar
This thread seems more fitting for StocS2k. And OP. Answers will be for both, skim for what you need.
Route the sensor just off the return line just before it goes steel in the front bottom. Sorry no pic.
I picked up SOS fuel pressure sensor Install adapter thing. You drill the fuel rail and then tap it. I used there "restrictor" to dampen pressure pulses but it almost stripped my AN fuel rail fitting because it pushed the steel line out from fully seating... Idk but it almost left me stranded. I took it back out and just living without it. I have not seem the "symptoms" it's suppose to correct anyways soo.
you can see the steel braided line for sensor just behind aem fpr.
as far as the ktuner goes, looking between management software (to me) it's like Mr. Miagi method and sensei John kreese method. Two ways to skin a cat. I don't particularly know enough to say which o e would be better for what but they do have different (mostly the same) butt... Different ways or titles for stuff that vice versa does not.
Old May 30, 2017 | 10:08 PM
I did the flex fuel sensor Install over night during actual kit so I did not get any pictures. I just followed SOS instructions.
Old May 30, 2017 | 11:08 PM
What r u tuning on?
Old May 30, 2017 | 11:36 PM
riceball777's Avatar
you just install the sensor in the return line. Here is mine
Old May 31, 2017 | 01:29 PM
Thank you everyone for the replies and all the great help! These are very inspirational and something I look forward to completing. I am currently running an AEM infinity with ID1000's / AEM 320 and a Novi1000. Hopefully I can get my fueling parts installed in the next 2 weeks! Any more help or criticism is welcomed, Thanks in adavance!
Old Jun 1, 2017 | 09:31 AM
nguyen365's Avatar
Are you changing out your fuel lines? I heard e85 will eat through the stock s2000 lines. We will have problems later. Still enjoying my 11.5 psi on 91 octane
There are guys on here that have been running e85 for a couple of years stock lines no issues tho..
Old Jun 2, 2017 | 06:39 PM
Charper732's Avatar
I am running an Infinity as well. I am not a fan of having gauges everywhere. I got a surface pro 3 I can mount and unmount when needed and it gives live feed for everything. It's pretty nice being able to make the car look stock when I want it. I'll take a picture of my setup in a minute
Old Jun 3, 2017 | 06:32 PM
Charper732's Avatar
This is my setup currently. The only gauge I run is A/F and I have a LED warning light for oil pressure. The surface pro 3 is a bit big for my liking. It helped out a ton initially with problem solving when we were shaking it down. Now that everything is settled I may try to find one smaller as I don't really need to have the VE table up.
Edit: just to add. You can buy a cheap ass tablet that is windows based for what the cost of the Zeitronix is...and you can view a hell of a lot more than just ethanol content..
Old Jun 3, 2017 | 10:02 PM
Mijae007's Avatar
Is it true running full e85 kills the wideband prematurely? What wideband are people here on e85 using?
