Post Your Dyno #'s And Mods!
Originally Posted by s0rted,Mar 6 2007, 03:02 PM
Why would your stock engine blow up with a higher octane fuel?
If anything it'll run stronger, as your ecu won't pull as much timing...
If anything it'll run stronger, as your ecu won't pull as much timing...Hotter the engine more likely to burn out your injectors or something if i remember right. Been along time ago when I was trying to put racing fuel in a Grand Am once...lmao.
Originally Posted by Sideways,Mar 30 2007, 04:10 PM
Just a little more boost and you should make the 400 club.
Where did you set your redline?
Originally Posted by shawnAMT,Mar 30 2007, 03:46 PM
vortech kit
750 cc injectors
7173 plugs
4" pulley
aem 1052
krankvents
Shawn Church tuning
380 whp 242 wtq at 10.35psi
750 cc injectors
7173 plugs
4" pulley
aem 1052
krankvents
Shawn Church tuning
do you have any headwork done? Are you using a 3mm head gasket? I thought it wasn't safe to run 10psi on a stock block correct me if i'm wrong
But I should get it done again now that the header is on perhaps.
