Preparing for SOT kit.
Old Apr 20, 2009 | 12:01 PM
roy365's Avatar
Originally Posted by vader1,Apr 20 2009, 10:02 AM
I have exchanged a few PM's in the past with Mark and probably will in the future. He has sent me lots of info and just trying to get some general stuff answered so I don't wear out my welcome with him.
He is the one who recommended the PLX unit.
i dont think he gets tired of helping with the SOT questions.
Old Apr 20, 2009 | 02:50 PM
s0rted's Avatar
Originally Posted by vader1,Apr 20 2009, 07:00 PM
Thanks for the responses. I am assuming the extra bung on the header is a standard thing any muffler shop can do or do you guys think I need to go to a performance shop?
It's been a while but if i remember correctly my plx came with a bung. Any half decent workshop should be able to do it, just make sure you get the angle correct, you don't want to foul your sensor. BTW, I had the PLX R500.
Old Apr 20, 2009 | 02:52 PM
s0rted's Avatar
Originally Posted by roy365,Apr 20 2009, 09:00 PM
any muffler shop SHOULD be able to do this. just make sure they know if its S/S or titanium before. Some will use a wire/flux specific for those materials. some dont. some of your aftermarket headers have an extra 02 bung for these situations.
Never heard of a titanium header avalaible for the S2000...
Old Apr 21, 2009 | 04:53 AM
roy365's Avatar
I was speaking in general bro. Sorry for the confusion.
Old Apr 21, 2009 | 06:11 AM
vader1's Avatar
There are only a couple. One from Amuse and one other I think. But I am stock.
Old Apr 21, 2009 | 06:12 AM
camuman's Avatar
everything your trying to prepare is correct. install all that to get out of the way. pump will not cuase any problems, same with plx, but i agree get another bung installed.
as for injectors, well if your good wiht tuning, you can isntall them and at least get it running decent. otherwise, you could always wait.
you got a pm
Old Apr 21, 2009 | 07:35 AM
MugenRioS2k's Avatar
Originally Posted by s0rted,Apr 20 2009, 11:33 AM
You don't replace the factory lambda sensor. That is still used by the your factory ecu since the emanage is a piggy-back and not a standalone. You'll need to tap an additional bung for the PLX - at the base of your exhaust manifiold is a good spot. I'm not sure how the ultimate works, only had the blue, but if I'm not mistaken you can then feed the wideband signal to the piggyback.
you can use the PLX wide band to replace your factory O2.
The PLX unit has a 0-1Volts output that feeds the factory ECU. (just like stock.
and a 0-5 volt to feed the Greddy Ultimate.
I have found that my stock ECU actually runs better with the 0-1V simulated narrowband input from the PLX then it did on the factory 0-1V narrowband voltage from the factory O2 sensor.
Install the fule pump
Run the car for a day or two; you should not see any problems.
Then install the ULT. With a base map that basically does nothing; so you can check your harness and jumper settings.
(I will send you a MAP when you need it)
Drive around for a couple of days
Again you should not see any problems.
Install the injectors and reflash the ULT with a MAP that scales the injectors appropriately.
( Again I will send you a MAP)
Drive around for a couple of days.
Again I would expect you to not have any problems.
Install the Supercharger when the time comes and I will send you the final map you need for the supercharger.
By taking this stepped approach you will have time to pin point any problems you may have before the supercharger goes on.
Old Apr 21, 2009 | 09:19 AM
vader1's Avatar
Thanks Mark.
Do you have a base map version with the added input from the wideband or will I need to input something into the map manually? And what is the target A/F with the wideband?
Old Apr 21, 2009 | 10:00 AM
yep
Got you covered no madder in what order you decide to install
Old Apr 21, 2009 | 10:18 AM
s0rted's Avatar
hey, for a minute there I was hoping you'd post up some pics
