pretty sure my diff exploded
Old Jul 4, 2010 | 07:24 PM
  #61
AusS2000's Avatar
Originally Posted by s2000Junky,Jul 5 2010, 11:48 AM
Go to the local Napa, Schucks, or where ever and just buy the socket to drain your diff.
23mm from memory.
Old Jul 5, 2010 | 10:02 AM
  #62
DFWs2k's Avatar
was a 24mm, there were a couple shavings on the magnetic diff drain plug, but no chunks of metal, so that means axle? Or could the chunks be too big to fit through the drain hole?
so the only axle that didn't look perfect was thedrivers side,so I guess I will order one? Any one-person tests to determine which axle is busted?
Old Jul 5, 2010 | 10:54 AM
  #63
dammitjim's Avatar
Did you remove the fill bolt on the diff first? I think that one is 23mm.
Old Jul 5, 2010 | 12:02 PM
  #64
DFWs2k's Avatar
no, damn it, lol, just popped off the bottom/drain bolt, would that affect whether or not huge metal pieces would come out? If I can get some wifi, i'll upload pic of axle
Old Jul 5, 2010 | 12:05 PM
  #65
dammitjim's Avatar
It won't affect anything coming out. It's just a good idea to make sure you can remove the fill bolt before removing the drain. It would suck if you can't get the fill bolt out.
Old Jul 5, 2010 | 12:22 PM
  #66
DFWs2k's Avatar
ah, ok, gotcha, i was able to remove the fill bolt last time when i changed the fluid, so hopefully i can get it again
time to look for driver's side axle, oreillys and autozone both said it'd be 3-4 weeks, fml
Old Jul 5, 2010 | 12:26 PM
  #67
dammitjim's Avatar
I'd look for a used one from a part out in the FS section
Old Jul 5, 2010 | 12:56 PM
  #68
DFWs2k's Avatar
yea, found one on car-part for $100 from an 04, but they dont know mileage/condition and it's an hour drive away
Old Jul 5, 2010 | 01:17 PM
  #69
dammitjim's Avatar
Cmon son
https://www.s2ki.com/forums/index.php?showtopic=766028
https://www.s2ki.com/forums/index.php?showtopic=775250
Old Jul 5, 2010 | 01:19 PM
  #70
DFWs2k's Avatar
lol, i already PMd both of them, local would be better so i can get this done quicker
