Priming the car before starting up after---
Old Oct 24, 2008 | 05:55 AM
JoeyBalls's Avatar
Default Priming the car before starting up after---
Hey, I pulled my turbo two weeks ago and my car will be sitting another week before I put the turbo on and fill it with oil, there is some residual oil I would imagine within the Turbo so should i prime the car before I start it up?
best way to prime? Pull the fuse for the fuel pump and crank it a few times?
Old Oct 24, 2008 | 06:02 AM
btstone84's Avatar
my shit sat for 3 months almost with no oil while i was waiting on parts. just put everything on and fill it with water and oil and crank it up and drive it
Old Oct 24, 2008 | 06:11 AM
John_Z's Avatar
Pull the plugs and disconnect the injectors and crank for about 20 seconds or until you read oil pressure(if you have a gauge).
Old Oct 24, 2008 | 06:16 AM
Venomous S's Avatar
Much easier to pull the EFI and Fuel pump fuse and then crank until you get oil pressure
Old Oct 24, 2008 | 06:26 AM
dsddcd's Avatar
You got it right pull the pump fuse and role it over several times
Old Oct 24, 2008 | 06:53 AM
JoeyBalls's Avatar
thanks, whats EFI?
Old Oct 24, 2008 | 06:57 AM
TelosHedge's Avatar
i just pull the coil packs
Old Oct 24, 2008 | 07:07 AM
JoeyBalls's Avatar
won't that flood the engine?
I think I am just going to pull the fuse for the Fuel Pump,
Old Oct 24, 2008 | 02:10 PM
Venomous S's Avatar
I meant to say EFI and Ignition instead
EFI = Electronic Fuel Injection, none other than the fuel pump
Old Oct 24, 2008 | 02:18 PM
JoeyBalls's Avatar
ok, so pull EFI & Ignition Fuses, then crank for 10 seconds or so?
