Priming the car before starting up after---
Old Oct 24, 2008 | 02:19 PM
AndyFloyd's Avatar
honestly you dont need to go through all this trouble, just pop it on an go.
Old Oct 24, 2008 | 02:22 PM
JoeyBalls's Avatar
nice, I figured there is still OIL in the Turbo and thats the most important part I would assume
Old Oct 24, 2008 | 02:26 PM
AndyFloyd's Avatar
yea the turbo has residual oil already in it....if you are at all worried put a couple drops in it and youre golden. At most your turbo will be w/o oil for a second or so.
Old Oct 25, 2008 | 10:14 AM
Venomous S's Avatar
Originally Posted by JoeyBalls,Oct 24 2008, 05:18 PM
ok, so pull EFI & Ignition Fuses, then crank for 10 seconds or so?
If my car sits for a long period of time as well as when I do an oil change I always like to build oil pressure before starting to make sure oil filter gets full of oil.
it's better to run dry at 500rpm's than run dry at 1200rpm's
Sure, there's residual oil left in bearings but when it comes to my car I always take the extra step to ensure things run smoother. It could mean the difference in months or years of service
Old Oct 25, 2008 | 10:26 AM
JoeyBalls's Avatar
I actually fill up my OIL filter with some oil before I start the car when I do an oil change, this way there is oil in it already
This a bad idea?
Old Oct 25, 2008 | 11:02 AM
TelosHedge's Avatar
1) take the send off the top of the turbo and fill it with oil. put send back on.
2) then remove your entire fuel system. pump, injectors, rail, and all relays.
3) drain blinker fluid, get an a/c recharge, and then tap the oil light 3 times with your INDEX FINGER on your right hand. INDEX FINGER.
4) put everything back together.
5) damnit joey stop worrying!!!!
i started my greddy turbo kit for the first time with no oil in it (pulled the wrong relay - hence now why i pull the coils) and never had a single issue. it didnt make a bad noise, nothing.
now go outside and turn on your damn car so we can move along to the next 'joey thinks he ****ed up something' thread
j/k you know we all love you
Old Oct 25, 2008 | 11:07 AM
JoeyBalls's Avatar
hahah I know I know I have had some shitty luck though. I do hope no one elses Log manifold cracks, I had around 12,000-13,000miles when it cracked. I think that is the most miles on the kit. I would imagine its cycles that crack a manifold not miles, and I do have a lot of cycles. I just cant wake up on a weekend and not take it for a drive somehwere
Old Oct 25, 2008 | 11:42 AM
AndyFloyd's Avatar
you turboed it to drive it, nothing wrong with that joey.
Old Oct 25, 2008 | 02:11 PM
Venomous S's Avatar
This a bad idea?
no, that helps as well, i do the same
Old Oct 25, 2008 | 02:14 PM
05TurboS2k's Avatar
Originally Posted by btstone84,Oct 24 2008, 07:02 AM
my shit sat for 3 months almost with no oil while i was waiting on parts. just put everything on and fill it with water and oil and crank it up and drive it
That's what I did.... I just put oil in it and it started right up.
NOTE:
AEM EMS doesn't start up quick if you don't let it sit 2-3seconds prior to pushing START so I did that on purpose to get like 6-10 cranks before it fired up... I figured that'd help run some oil around.
-G
waytooslow
Jul 14, 2009 07:10 PM
s2guru
Jun 19, 2009 03:11 PM
markS2kcU
May 19, 2007 10:00 PM
