Process of Upping the Boost CTSC
Old Sep 5, 2008 | 11:37 AM
S2k_RN's Avatar
Default Process of Upping the Boost CTSC
So I'm going to up the boost to about 10psi and will be tuning using the Emanage Ultimate. In attempt to save some money with installation cost. Basically I want to remove and reinstall as much as possible.
1) Can I changed the pulley and still drive it to the tuner? Of course I will go easy and avoid going into boost/WOT.
2) Can I remove the stock FMU, put the stock FPR back on and still drive it to the tuner?
3) I will be using the boomslang plug n' play harness. Will I need to remove the ESM and re-wire the map sensor wires? Or do I keep the ESM on?
4) Does anyone have a base map for CTSC S2k that I can have?
Still a noob with FI and just want to do everything right. If I can't cut labor cost without possibly damaging the car then I won't. Any help is greatly appreciated.
Thanks.
Old Sep 5, 2008 | 11:55 AM
Danks2k's Avatar
What I did to not chance it was to put the new pulley on and route the belt but zip tie it out of the way of the crank pulley. When you get to the tuner put the belt on the pulley and tighten it. This way you can remove your fmu and put the stock fpr back as well.
Old Sep 5, 2008 | 12:52 PM
dsddcd's Avatar
I have a Turbo program for an AP1
Old Sep 6, 2008 | 07:15 AM
nightcrawler7188's Avatar
let us know how the tune goes! i have AP1 with ctsc as well.. i'm going to have the same setup...got the emanage ultimate, injectors, and going to get a 10psi pulley soon.
Old Sep 6, 2008 | 07:21 AM
TelosHedge's Avatar
Put the pulley on but just leave the belt off. That makes you na for the drive
Old Sep 6, 2008 | 09:32 AM
Enthralled's Avatar
as long as you do not go into boost, you can leave the belt on. I drove over 250 miles with my upgraded pulley without a tune.
Old Sep 6, 2008 | 11:10 AM
S2k_RN's Avatar
Thanks everyone. Thanks dsddcd but I don't know if there's a difference with turbo and supercharger basemap I would imagine that it will be different. Does anyone have a basemap for a supercharger?
Another thing is do I need to remove ESM?
Nightcrawler I'll keep you updated.
Old Sep 6, 2008 | 11:23 AM
Enthralled's Avatar
you won't need the ESM anymore if going with the EMU.
Old Sep 6, 2008 | 11:28 AM
S2SEXY's Avatar
leave the belt on and just don't connect the charge pipe.take the esm off and the fpr.why waste time at the tuner
EriS2k
Jun 17, 2015 04:27 PM
s2konroids
Oct 11, 2011 12:47 PM
s2konroids
Jul 21, 2011 09:22 AM
sloweg
Oct 31, 2007 05:38 PM
johninator
Mar 12, 2005 06:16 AM
