producing more boost then spring size
Old Oct 21, 2013 | 09:26 AM
il_robu89's Avatar
Default producing more boost then spring size
Hi guys , i have two 44mm gates on my afi t4 twinscroll setup with 5psi springs !
borg wagner s362 1.00 a/r and 3" full exhaust ..!
I have tested the car yesterday without any boost control and my map sensor read more than 10,5 psi..!!
what's wrong?
Old Oct 21, 2013 | 09:48 AM
passmans2kny's Avatar
its creeping
Old Oct 21, 2013 | 10:14 AM
siadam's Avatar
what's wrong?
Big turbo's on low boost need bigger gates generally, remember you are asking a turbo that can flow a ginormous amount of air to "bypass" 90% of that air on low boost, so it needs somewhere to go, i.e. a bigger gate.
Old Oct 21, 2013 | 12:12 PM
il_robu89's Avatar
My target is 13 /14 psi
Old Oct 22, 2013 | 07:59 PM
pettyboy69's Avatar
Agree with what has already been said, also I have personally seen the same exact turbo, manifold, and wastegate combo run different boost on different motors. No motor will ever be exactly the same
MorngWoodStewie
Jun 29, 2017 11:27 AM
s2konroids
Aug 19, 2014 06:45 AM
stantaur
Feb 14, 2013 08:53 AM
s2kantstopme
Feb 23, 2007 10:51 AM
shauminside
Aug 8, 2004 06:45 AM
