PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old Dec 31, 2011 | 03:58 AM
  #1951
ArchAngel2K's Avatar
I did. Not much room to work with lol. I need to find my little mirror. Oh 1 more thing. What is the spring in the hypergate? It's over 10 lbs for sure
Old Dec 31, 2011 | 07:45 AM
  #1952
robotvoice's Avatar
Originally Posted by dales2000
Originally Posted by ArchAngel2K' timestamp='1325295976' post='21274939
This vband lining up nonsense is really causing problems for me. A tiny leak between the mani and turbo
It helps to have a second person hold the turbo flush against the manifold while you tighten the clamp.
Having an extra set of hands for this part is crucial, but even with that it took a good 3 or 4 tries to get mine lined up perfectly.
Old Dec 31, 2011 | 08:00 AM
  #1953
dales2000's Avatar
Originally Posted by robotvoice
Originally Posted by dales2000' timestamp='1325307891' post='21275206
[quote name='ArchAngel2K' timestamp='1325295976' post='21274939']
[/quote]
I agree I had my ex help me and it made things easy because of her small hands. another option is taking the turbo and manifold out the car line it up perfectly and tighten the vband just enough to where it can still rotate with some force for adjusting.
Old Dec 31, 2011 | 08:23 AM
  #1954
MrC@PTUNING's Avatar
[/quote]
The tial vband clamp has a very shallow v-groove so it can be tricky securing the flanges together perfectly with the clamp. The best way to align the turbine inlet flange is to use the supply non-locking nut on the clamp and turn the nut with your finger while you rotate the turbo back and forth on the mating surface as you're slowing tightening the clamp, the male to female face will quickly line up. The trick is to get the clamp tight enough initially to hold up the turbo (having an extra hand would make it simpler)
Once the vband flange is fully mated, tighten the non-locking nut just enough so that the turbine housing can still be rotated with a little bit of effort. Install the downpipe and align it with the exhaust before going back to fully securing the v-band clamp with the locking nut. If you have any other questions just give us a call or pm.
Also the hyper gate comes with a 7psi spring.
MrC
Old Dec 31, 2011 | 08:26 AM
  #1955
Thanks Dale and Steve for your input
MrC
Old Dec 31, 2011 | 11:03 PM
  #1956
Originally Posted by MrC@PTUNING
Originally Posted by robotvoice' timestamp='1325349947' post='21275774
[quote name='dales2000' timestamp='1325307891' post='21275206']
[/quote]
MrC
[/quote]
really its only 7lbs? i have it running on spring and a fuel cut at 10psi. well needless to say it makes it up to 10 without opening so i hit the fuel cut
Old Jan 1, 2012 | 09:28 AM
  #1957
miguel329's Avatar
did you put the restrictor plate in? mine did that before i put that plate between dp and tesp pipe. still creeps not as bad
Old Jan 2, 2012 | 11:18 PM
  #1958
VTECS2K's Avatar
Ordered my kit. Excited and can't wait to receive it. Thanks again Andrew. Ptuning FTW
Old Jan 3, 2012 | 03:46 AM
  #1959
HMFIC's Avatar
Congrats! and welcome aboard!
Old Jan 3, 2012 | 03:49 AM
  #1960
sparrow's Avatar
