PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
andrew I, pmed you for the pack of 3 tabs... im getting ready for retune on e85...also for the wastegate the thread sections you carry the bolt to block unused ports?going mac solonoid instead of manual boost controller need to block some of the top ports.thanks
just so you are aware if manifold cracks you wont have warranty on the fix,since it does,nt transfer from customer to customer, unless ptuning changed that policy, figured be good to let you know...you will be happy with the kit.. i put over 10k miles with only problem being the driver side oem mount broke twice(swapped to hasport mount on that side fix problem), and intake is rite behind the fan so sucks up the radiator heat....other then that solid kit.
Originally Posted by S2KCHRIS305' timestamp='1354729910' post='22191621
Ok perfect , im definantly gonna purchase the mount sometime next week, gonna pick up my used ptunning kit this weekend, thanks so much guys
Thanks Drew. R 703-257-1728
Hello everyone, we are currently running a special on the ptuning oil cooler kit for the s2k. Take a look at the link below.
https://www.s2ki.com/s2000/topic/993...ntil-12312012/
Ptuning,
I applaud you guys on a impressive well sought out kit. Unfortunately, I don't have the funds to purchase one now.
Im new to the boost world and im wondering what all is needed for turn key?
Kit
Fuel ecu kit
Clutch
Radiator (suggested)
Wideband?
Drivers motor mount
Any gauges? Or will I be ok by checking flash pro?
Thank you guys
Kit
Fuel ecu kit
Clutch
Wideband?
Drivers motor mount
Thank you guys
Ptuning,
Kit
Fuel ecu kit
Clutch
Wideband?
Drivers motor mount
Thank you guys
Kit
Fuel ecu kit
Clutch
Wideband?
Drivers motor mount
Thank you guys
